Want to change ESP32 tcp port number in AP mode
david@mandy
Postby david@mandy » Tue Jun 12, 2018 9:25 am
Hello Admin,
I am using ESP 32 with esp-idf v3.0 (stable version). I am using TCP/IP in my application. In my code I have assigned the TCP IP and port number(80) and using browser I am trying to open one html page, and it is working fine. But when I change the port number in my code, the device is not able to push the html page. I tried with different port numbers but every time it is failing. It is only working with one port number i.e 80. I also tried with "TCP UDP test tool" app with different port numbers, but there it worked as expected. Only with the browser I am facing this problem.
WiFive
Re: Want to change ESP32 tcp port number in AP mode
Postby WiFive » Tue Jun 12, 2018 9:29 am
What are you typing in the browser for port 88? Http://192.168.4.1:88 ?
david@mandy
Postby david@mandy » Wed Jun 13, 2018 5:53 am
Hello WiFive,
Thanks for your response.
When I am typing "http://192.168.4.1:80" in the browser it is working.
Suppose if I set the port number 88 and in the browser I type "http://192.168.4.1:88" , at that time device is not able to push the html page.
Thanks.
kolban
Postby kolban » Wed Jun 13, 2018 2:01 pm
What is the symptom of the failure? Is there any indication that the browser requests are being received by the ESP32 device?
deneme
Postby deneme » Mon Oct 18, 2021 6:00 am
Is there a solution on this problem. I got the same problem. When I change port number other than 80 esp8266webserver does not respond to client.
Users browsing this forum: Bing [Bot], Bytespider, Google [Bot] and 5 guests
