Hallo all,
i would like to know if it is possible to generate a constant frequency of 1.024 Mhz (~1Mhz) on a PIN and if so do you have example codes?
Many thanks in advance
Generatig a clock frequency
Re: Generatig a clock frequency
Because im not an expert at hardware level, could you try to explain the following attributes:
- ledc_channel_config_t.duty
ledc_timer_config_t.duty_resolution
Should i use LEDC_APB_CLK_HZ which gives 80MHz or LEDC_REF_CLK_HZ with 1MHz?
For example without tesing:
periph_module_enable(PERIPH_LEDC_MODULE);
int bit_width = 8; // idk
int divider = 80; // 80MHz / 80 ~ 1MHz
int duty_cycle = 1 << (bit_width - 1); // ?? 128
float freq_hz = ((uint64_t) LEDC_APB_CLK_HZ << 8) / (float) divider / (1 << bit_width);
printf("frequency: %f Hz\n", freq_hz);
ledc_timer_set(LEDC_HIGH_SPEED_MODE, LEDC_TIMER_0, divider, bit_width, LEDC_APB_CLK_HZ );
ledc_timer_rst(LEDC_HIGH_SPEED_MODE, LEDC_TIMER_0);
ledc_timer_resume(LEDC_HIGH_SPEED_MODE, LEDC_TIMER_0);
ledc_channel_config_t channel_config = {
.channel = LEDC_CHANNEL_0,
.duty = duty_cycle,
.gpio_num = GPIO_NUM_2,
.speed_mode = LEDC_HIGH_SPEED_MODE,
.timer_sel = LEDC_TIMER_0
ledc_channel_config(&channel_config);
Divider has 8-bit fractional part, so you probably need to set it to 80MHz/1.024MHz*256=20000.
Bit_num=8 and duty=127 seems to be okay, should generate 50% duty cycle.
Thank you, i solved that with the following code:Divider has 8-bit fractional part, so you probably need to set it to 80MHz/1.024MHz*256=20000.
int bit_width = 1; // 1 - 20 bits
int divider = 10240; // Q10.8 fixed point number, 0x100 — 0x3FFFF
ledc_timer_set(LEDC_HIGH_SPEED_MODE, LEDC_TIMER_0, divider, bit_width, LEDC_APB_CLK);
ledc_channel_config_t channel_config = {0};
channel_config.channel = LEDC_CHANNEL_0;
channel_config.duty = duty_cycle;
channel_config.gpio_num = PIN_CLOCK;
channel_config.speed_mode = LEDC_HIGH_SPEED_MODE;
channel_config.timer_sel = LEDC_TIMER_0;
ledc_channel_config(&channel_config);Who is online
Users browsing this forum: Bing [Bot], trendictionbot and 1 guest
