"Guru Meditation Error: Core 1 panic'ed (InstrFetchProhibited)" error
zam_ii
Postby zam_ii » Fri Jun 22, 2018 4:03 am
I tried to connect to IoT platform from ESP32 through MQTT.
My code as below. There is no problem when I use Adafruit MQTT broker.
But I got a "Guru Meditation Error: Core 1 panic'ed (InstrFetchProhibited)" error when tried to send MQTT to this IoT platform.
Is it due to the key is too long? Is there any solution?
#include "WiFi.h"
#include "PubSubClient.h"
const char* ssid = "*****";
const char* password = "*****";
const char* mqtt_server = "mqtt.favoriot.com";
const char* username = "eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJ1c2VybmFtZSI6ImlsemFtYWxwcyIsInJlYWRfd3JpdGUiOnRydWUsImlhdCI6MTUyODQ0ODQwN30.7ChIJzlW0Ja7QGR_sO6T04yh3pCY9tEqPbf********";
const char* passkey = "eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJ1c2VybmFtZSI6ImlsemFtYWxwcyIsInJlYWRfd3JpdGUiOnRydWUsImlhdCI6MTUyODQ0ODQwN30.7ChIJzlW0Ja7QGR_sO6T04yh3pCY9tEqPbf********";
const char* topic = "eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJ1c2VybmFtZSI6ImlsemFtYWxwcyIsInJlYWRfd3JpdGUiOnRydWUsImlhdCI6MTUyODQ0ODQwN30.7ChIJzlW0Ja7QGR_sO6T04yh3pCY9tEqPbf********/all";
WiFiClient espClient;
PubSubClient client(espClient);
void mqttconnect() {
  while (!client.connected()) {
    Serial.print("MQTT connecting ...");
    String clientId = "ESP32";
    if (client.connect(clientId.c_str(),username,passkey)) {
      Serial.println("connected");
    } else {
      Serial.print("failed, status code =");
      Serial.print(client.state());
      Serial.println("try again in 5 seconds");
      delay(5000);
void setup() {
  Serial.begin(115200);
  Serial.println();
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  client.setServer(mqtt_server, 1883);
void loop() {
  if (!client.connected()) {
    mqttconnect();
   String json = "{\"device_developer_id\":\"deviceDefault@ilzamalps\",\"data\":{\"humidity\":\"80\",\"temperature\":\"30\"}}";
   client.publish(topic,json.c_str());
   delay(30000);
Connecting to zamii@unifi
WiFi connected
IP address:
192.168.0.148
MQTT connecting ...Guru Meditation Error: Core  1 panic'ed (InstrFetchProhibited)
. Exception was unhandled.
Register dump:
PC      : 0x00000000  PS      : 0x00060030  A0      : 0x800d21a8  A1      : 0x3ffd0ca0
A2      : 0x3ffc3224  A3      : 0x3ffd0cac  A4      : 0x00000000  A5      : 0x00000155
A6      : 0x00000003  A7      : 0x00000000  A8      : 0x800d2090  A9      : 0x00000002
A10     : 0x3ffc32d4  A11     : 0x3ffc322a  A12     : 0x00000158  A13     : 0xfb792634
A14     : 0xfb792634  A15     : 0x3ffc3b14  SAR     : 0x00000018  EXCCAUSE: 0x00000014
EXCVADDR: 0x00000000  LBEG    : 0x400d210d  LEND    : 0x400d211c  LCOUNT  : 0x00000000
Backtrace: 0x00000000:0x3ffd0ca0 0x400d21a5:0x3ffd0cd0 0x400d2266:0x3ffd0d10 0x400d13c8:0x3ffd0d40 0x400d14b3:0x3ffd0d70 0x4010cf50:0x3ffd0da0
Rebooting...
ets Jun  8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:956
load:0x40078000,len:0
load:0x40078000,len:13076
entry 0x40078ad0
ajithcs
Re: "Guru Meditation Error: Core 1 panic'ed (InstrFetchProhibited)" error
Postby ajithcs » Sat Jun 23, 2018 5:44 am
I tried your code and I test it to "test.mosquitto.org" without username and passkey
const char* mqtt_server = "test.mosquitto.org";
const char* topic = "temp/random";
if (client.connect(clientId.c_str())) {
and i got successfully connected.
Connecting to CONNECTSA
WiFi connected
IP address:
192.168.0.103
MQTT connecting ...connected
Postby Sprite » Sun Jun 24, 2018 2:07 am
Are you sure your power supply is adequate?
zam_ii
Postby zam_ii » Sun Jun 24, 2018 9:56 pm
Same as me, tried using others mqtt broker, no problem.
As mentioned using other mqtt broker, connect this board to laptop using usb cable, no problem.
ajithcs
Postby ajithcs » Mon Jun 25, 2018 10:25 am
Post by ESP_Sprite » Sun Jun 24, 2018 7:37 am
hi, thanks for the reply.
But no power supply issues.
zam_ii
Postby zam_ii » Mon Jun 25, 2018 3:12 pm
Please help, any idea?
