Hi
Can you please tell me why this setting is unstable and the oscilloscope output can see bending as otherwise I could set the timer to be stable at 40Khz thank you for your advice.
my code
#include "driver/timer.h"
static intr_handle_t s_timer_handle;
void init_timer(uint64_t timer_period_us)
timer_config_t config = {
.alarm_en = true,
.counter_en = false,
.intr_type = TIMER_INTR_LEVEL,
.counter_dir = TIMER_COUNT_UP,
.auto_reload = true,
.divider = 80
timer_init(TIMER_GROUP_0, TIMER_1, &config);
timer_set_counter_value(TIMER_GROUP_0, TIMER_1, 0);
timer_set_alarm_value(TIMER_GROUP_0, TIMER_1, timer_period_us);
timer_enable_intr(TIMER_GROUP_0, TIMER_1);
timer_isr_register(TIMER_GROUP_0, TIMER_1, &timer_isr, NULL, 0, &s_timer_handle);
timer_start(TIMER_GROUP_0, TIMER_1);
static void IRAM_ATTR timer_isr(void* arg){
TIMERG0.int_clr_timers.t1 = 1;
TIMERG0.hw_timer[1].config.alarm_en = 1;
digitalWrite(23, digitalRead(23) ^ 1);
void setup() {
pinMode(23, OUTPUT);
init_timer(12);
void loop() {
40khz Timer setup
Re: 40khz Timer setup
Your post doesn't really make sense. In what way is your output unstable and what do you mean by 'bending'?
...That scope screenshot doesn't really make much sense, as it seems to show a 33Hz signal. In general, if you want to make a square wave, why not use e.g. the LEDPWM peripheral, by the way?
The picture is just an example of it being seen only a problem with the timer ledc library works correctly that i tried but i need to set the timer to the frequency of 40khz my project.
When I use ledc library so the output signal is OK even at 80khz but as suddenly I use my code using the timer so the signal is unstable
Users browsing this forum: Google [Bot], meta-externalagent, Qwantbot and 1 guest
