IR Transmitter
bibble235
IR Transmitter
Postby bibble235 » Fri Jun 01, 2018 9:05 am
I have bought
https://www.jaycar.us/arduino-compatibl ... e/p/XC4426
And want to run it on a ESP wroom 32
I am very new to all this but come from an IT background. I used the code below and cannot see the IR working with a digital phone which does show when I use a remote.
int IRledPin = 17;
void setup() {
	pinMode(IRledPin, OUTPUT);
	Serial.begin(9600);
void loop() {
	delay(2000);
	SendNikonCode();
	Serial.println("Sending IR signal");
	delay(300);
void pulseIR(long microsecs) {
	cli();
	while (microsecs > 0) {
		digitalWrite(IRledPin, HIGH);
		delayMicroseconds(10);
		digitalWrite(IRledPin, LOW);
		microsecs -= 26;
	sei();
void SendNikonCode() {
	pulseIR(2080);
	delay(27);
	pulseIR(440);
	delayMicroseconds(1500);
	pulseIR(460);
	delayMicroseconds(3440);
	pulseIR(480);
	delay(65);
	pulseIR(2000);
	delay(27);
	pulseIR(440);
	pulseIR(460);
	pulseIR(480);
I have some questions
- is this the easiest way to test id the transmitter works?
- esp32 talks about IR, is there an on board IR
- is there a code sample for this
- what library should I use to get an IR transmitter to work
I assumed the middle pin is for the 5v as this was the case with the receiver. I does not show on the pinout but adding this to check I have not blown the transmitter.
I have got the receiver working so I am not a complete idiot but please be gentle with me.
Thanks all,
Iain
keckert
Re: IR Transmitter
Postby keckert » Sun Jun 03, 2018 11:18 pm
I find very little useful information about that IR transmitter. The "datasheet" shows:
  • 5 volt operation
  • Two pins: signal and ground.
  • There is a place on the board to put a surface-mount resistor, but there is no resistor mounted there.
I would assume that this device is a bare IR LED. That does not match the description of it being a 5 volt device. Since the ESP32 operating voltage upper limit is 3.6 volts, your LED is not directly compatible with the ESP32. You can still use it if you have a level shifting amplifier circuit. See the two-resistor and one-transistor circuit in my GitHub:
https://github.com/kimeckert/ESP32-RMT- ... driver.png
The code at this site is an example of transmitting a simple pattern through the ESP32 RMT peripheral.
https://github.com/kimeckert/ESP32-RMT-server
The ESP32 has a smart IR driver circuit, the RMT. See the ESP32 documentation. The aforementioned GitHub example uses the RMT to transmit IR codes. Other sample code is at:
https://github.com/espressif/esp-idf/tr ... _nec_tx_rx
This is an example of the ESP32 decoding a hex value and sending the resulting pattern through the RMT.
The easiest way to test an IR LED is to look at it through a cell phone camera. You probably should not point the LED directly into your camera. You should be able to see the LED off-axis when the LED is forward biased.
fejess
Re: IR Transmitter
Postby fejess » Wed Aug 22, 2018 11:48 am
I'm working on the same thing, just in my case there is no way to use RMT.
gpio: 23,22,21,19,18,25,26,27 are for ETH
gpio: 16, 17 for hardware Serial (RS485)
uart1: gpio 9, 10 cant use.
But there is a gpio 32 as digital OUTPUT.
The same way as @bibble235 wrote it looks like working.
Successfully copyed a signal with logic analyser.
At the moment I waiting for prototype board to test the signal.
Searched in github, but nothing useful library for digitalWrite signal creator.
Have you found something already? Or I need to write a lib for this :/
fejes
Deouss
Re: IR Transmitter
Postby Deouss » Wed Aug 22, 2018 12:47 pm
Maybe this post will help
https://esp32.com/viewtopic.php?f=17&t=5960&p=25764
I worked recently on IR receive/send and had no issues using RMT.
It actually works very good with higher frequencies like 50-100khz
I'm not sure if you have to use any library but I was not using Arduino.
You have 8 RMT independent channels to use as infrared transceiver on esp.
mikemoy
Re: IR Transmitter
Postby mikemoy » Wed Aug 22, 2018 12:51 pm
They are using that board as dual purpose, that's why there are other placed for parts that are no on it.
You need to be using the circuit @keckert showed to drive it. That IR led cannot handle +5v directly.
Odds are if you shot +5v into it, you already toasted the IR led.
Users browsing this forum: Bing [Bot] and 2 guests
