I'm not sure if this is a hardware issue or config issue or something else so I post it here first.
The system does not wake up properly anymore after the ***2nd*** deep sleep period (and any deep sleep period after that) using ESP-IDF v3.2-dev-607-gb14e87a6. It seems to reset itself twice (with different reset codes) during boot losing the deep sleep context and RTC variable's data. The app uses esp_sleep_enable_timer_wakeup(). It happens consistently.
@note The wakeup after the 1st deep sleep period always works fine. The esp_sleep_get_wakeup_cause() returns Timer and the value of an RTC_DATA_ATTR variable is kept alive.
The bootstrap messages are somewhat different at the beginning of the problematic wakeups. It seems to reset twice? :
ets Jun 8 2016 00:22:57
rst:0x5 (DEEPSLEEP_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
rst:0x7 (TG0WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0010,len:4
load:0x3fff0014,len:5940
load:0x40078000,len:9308
load:0x40080400,len:5780
entry 0x40080744
- Development Kit: [Adafruit HUZZAH32] I tried 2 boards
- Core (if using chip or module): [ESP-WROOM32]
- IDF version (commit id): ESP-IDF v3.2-dev-607-gb14e87a6 Aug25,2018 ESP-IDF
- Development Env: [Eclipse]
- Operating System: [Windows]
- Power Supply: [USB from hub]
### Workaround
Go back to esp-idf tag v3.2-dev
### Steps to repropduce
cd ~
git clone --recursive https://github.com/pantaluna/support_esp_espidf_deep_sleep.git
cd support_esp_espidf_deep_sleep
make erase_flash; make flash monitor
(This is a very minimalistic programme)
https://github.com/pantaluna/support_es ... deep_sleep
## Debug Logs
Python requirements are satisfied.
MONITOR
--- idf_monitor on COM12 115200 ---
entry 0x40080744
I (175) boot: ESP-IDF v3.2-dev-607-gb14e87a6 2nd stage bootloader
I (176) boot: compile time 23:01:09
I (176) boot: Enabling RNG early entropy source...
I (196) boot: SPI Speed : 40MHz
I (209) boot: SPI Mode : DIO
I (222) boot: SPI Flash Size : 4MB
I (235) boot: Partition Table:
I (246) boot: ## Label Usage Type ST Offset Length
I (269) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (292) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (315) boot: 2 factory factory app 00 00 00010000 00100000
I (339) boot: End of partition table
I (352) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x060b0 ( 24752) map
I (433) esp_image: segment 1: paddr=0x000160d8 vaddr=0x3ffb0000 size=0x0210c ( 8460) load
I (456) esp_image: segment 2: paddr=0x000181ec vaddr=0x3ffb210c size=0x00000 ( 0) load
I (457) esp_image: segment 3: paddr=0x000181f4 vaddr=0x40080000 size=0x00400 ( 1024) load
0x40080000: _WindowOverflow4 at C:/myiot/esp/esp-idf/components/freertos/xtensa_vectors.S:1685
I (485) esp_image: segment 4: paddr=0x000185fc vaddr=0x40080400 size=0x07a14 ( 31252) load
I (590) esp_image: segment 5: paddr=0x00020018 vaddr=0x400d0018 size=0x11734 ( 71476) map
0x400d0018: _flash_cache_start at ??:?
I (745) esp_image: segment 6: paddr=0x00031754 vaddr=0x40087e14 size=0x01dbc ( 7612) load
0x40087e14: rtc_clk_cpu_freq_get_config at C:/myiot/esp/esp-idf/components/soc/esp32/rtc_clk.c:472
I (767) esp_image: segment 7: paddr=0x00033518 vaddr=0x400c0000 size=0x00064 ( 100) load
I (769) esp_image: segment 8: paddr=0x00033584 vaddr=0x50000000 size=0x00004 ( 4) load
I (794) esp_image: segment 9: paddr=0x00033590 vaddr=0x50000004 size=0x00000 ( 0) load
I (858) boot: Loaded app from partition at offset 0x10000
I (859) boot: Disabling RNG early entropy source...
I (864) cpu_start: Pro cpu up.
I (875) cpu_start: Starting app cpu, entry point is 0x40080f38
0x40080f38: call_start_cpu1 at C:/myiot/esp/esp-idf/components/esp32/cpu_start.c:226
I (1) cpu_start: App cpu up.
I (908) heap_init: Initializing. RAM available for dynamic allocation:
I (928) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (947) heap_init: At 3FFB3160 len 0002CEA0 (179 KiB): DRAM
I (966) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (986) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1005) heap_init: At 40089BD0 len 00016430 (89 KiB): IRAM
I (1025) cpu_start: Pro cpu start user code
I (351) cpu_start: Starting scheduler on PRO CPU.
I (352) myapp: OK Task has been created, and is running right now
I (352) myapp: main_task()
I (352) myapp: END app_main()
I (352) myapp: *** Wakeup reason: UNKNOWN (not after a deep sleep period, probably after a normal reset)
I (372) myapp: ***(RTC_DATA_ATTR static uint32_t mcu_boot_count): 1
I (382) myapp:
***SECTION: DEEP SLEEP***
I (382) myapp: Entering deep sleep (the MCU should wake up 10 seconds later)...
entry 0x40080744
I (59) boot: ESP-IDF v3.2-dev-607-gb14e87a6 2nd stage bootloader
I (59) boot: compile time 23:01:09
I (60) boot: Enabling RNG early entropy source...
I (66) boot: SPI Speed : 40MHz
I (70) boot: SPI Mode : DIO
I (74) boot: SPI Flash Size : 4MB
I (79) boot: Partition Table:
I (82) boot: ## Label Usage Type ST Offset Length
I (90) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (97) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (105) boot: 2 factory factory app 00 00 00010000 00100000
I (113) boot: End of partition table
I (117) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x060b0 ( 24752) map
I (144) esp_image: segment 1: paddr=0x000160d8 vaddr=0x3ffb0000 size=0x0210c ( 8460) load
I (152) esp_image: segment 2: paddr=0x000181ec vaddr=0x3ffb210c size=0x00000 ( 0) load
I (152) esp_image: segment 3: paddr=0x000181f4 vaddr=0x40080000 size=0x00400 ( 1024) load
I (162) esp_image: segment 4: paddr=0x000185fc vaddr=0x40080400 size=0x07a14 ( 31252) load
I (197) esp_image: segment 5: paddr=0x00020018 vaddr=0x400d0018 size=0x11734 ( 71476) map
I (248) esp_image: segment 6: paddr=0x00031754 vaddr=0x40087e14 size=0x01dbc ( 7612) load
I (256) esp_image: segment 7: paddr=0x00033518 vaddr=0x400c0000 size=0x00064 ( 100)
I (256) esp_image: segment 8: paddr=0x00033584 vaddr=0x50000000 size=0x00004 ( 4)
I (264) esp_image: segment 9: paddr=0x00033590 vaddr=0x50000004 size=0x00000 ( 0)
I (285) boot: Loaded app from partition at offset 0x10000
I (285) boot: Disabling RNG early entropy source...
I (287) cpu_start: Pro cpu up.
I (291) cpu_start: Starting app cpu, entry point is 0x40080f38
I (0) cpu_start: App cpu up.
I (302) heap_init: Initializing. RAM available for dynamic allocation:
I (308) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (315) heap_init: At 3FFB3160 len 0002CEA0 (179 KiB): DRAM
I (321) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (327) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (334) heap_init: At 40089BD0 len 00016430 (89 KiB): IRAM
I (340) cpu_start: Pro cpu start user code
I (350) cpu_start: Starting scheduler on PRO CPU.
I (351) myapp: OK Task has been created, and is running right now
I (351) myapp: main_task()
I (351) myapp: END app_main()
I (351) myapp: *** Wakeup reason: TIMER
I (361) myapp: ***(RTC_DATA_ATTR static uint32_t mcu_boot_count): 2
I (371) myapp:
I (371) myapp: Entering deep sleep (the MCU should wake up 10 seconds later)...
entry 0x40080744
W (178) boot: PRO CPU has been reset by WDT.
W (179) boot: WDT reset info: PRO CPU PC=0xdfa8224
W (179) boot: WDT reset info: APP CPU PC=0xbc77af4a
I (199) boot: ESP-IDF v3.2-dev-607-gb14e87a6 2nd stage bootloader
I (220) boot: compile time 23:01:09
I (233) boot: Enabling RNG early entropy source...
I (250) boot: SPI Speed : 40MHz
I (263) boot: SPI Mode : DIO
I (275) boot: SPI Flash Size : 4MB
I (288) boot: Partition Table:
I (299) boot: ## Label Usage Type ST Offset Length
I (322) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (345) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (369) boot: 2 factory factory app 00 00 00010000 00100000
I (392) boot: End of partition table
I (405) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x060b0 ( 24752) map
I (487) esp_image: segment 1: paddr=0x000160d8 vaddr=0x3ffb0000 size=0x0210c ( 8460) load
I (509) esp_image: segment 2: paddr=0x000181ec vaddr=0x3ffb210c size=0x00000 ( 0) load
I (511) esp_image: segment 3: paddr=0x000181f4 vaddr=0x40080000 size=0x00400 ( 1024) load
I (538) esp_image: segment 4: paddr=0x000185fc vaddr=0x40080400 size=0x07a14 ( 31252) load
I (643) esp_image: segment 5: paddr=0x00020018 vaddr=0x400d0018 size=0x11734 ( 71476) map
I (799) esp_image: segment 6: paddr=0x00031754 vaddr=0x40087e14 size=0x01dbc ( 7612) load
I (820) esp_image: segment 7: paddr=0x00033518 vaddr=0x400c0000 size=0x00064 ( 100) load
I (822) esp_image: segment 8: paddr=0x00033584 vaddr=0x50000000 size=0x00004 ( 4) load
I (847) esp_image: segment 9: paddr=0x00033590 vaddr=0x50000004 size=0x00000 ( 0) load
I (911) boot: Loaded app from partition at offset 0x10000
I (912) boot: Disabling RNG early entropy source...
I (918) cpu_start: Pro cpu up.
I (928) cpu_start: Starting app cpu, entry point is 0x40080f38
I (961) heap_init: Initializing. RAM available for dynamic allocation:
I (982) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (1000) heap_init: At 3FFB3160 len 0002CEA0 (179 KiB): DRAM
I (1020) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (1039) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1059) heap_init: At 40089BD0 len 00016430 (89 KiB): IRAM
I (1079) cpu_start: Pro cpu start user code
I (368) cpu_start: Starting scheduler on PRO CPU.
I (370) myapp: OK Task has been created, and is running right now
I (370) myapp: main_task()
I (370) myapp: END app_main()
I (370) myapp: *** Wakeup reason: UNKNOWN (not after a deep sleep period, probably after a normal reset)
I (390) myapp: ***(RTC_DATA_ATTR static uint32_t mcu_boot_count): 1
I (400) myapp:
I (400) myapp: Entering deep sleep (the MCU should wake up 10 seconds later)...
entry 0x40080744
W (179) boot: WDT reset info: APP CPU PC=0xbc77af0a
I (400) myapp:
