PSRAM/SD card/PICO D4
eakerdr@gmail.com
Postby eakerdr@gmail.com » Wed Aug 22, 2018 4:08 pm
Is there a schematic or reference design that shows the PICO D4 hooked to an SD card AND to an SRAM chip (ESP-PSRAM64H) AND it works!
thethinker
Re: PSRAM/SD card/PICO D4
Postby thethinker » Mon Aug 27, 2018 6:32 pm
Hi guys,
Any comments on this?
I'm also trying to do the same.
I have the SD card fully working with the PICO-D4, I was about to change to the standard chip rather than the SOP since the SPRAM was only available in 1.8V and that wouldn't work with the internal 3.3V flash, but now there is a 3.3V version of the SPRAM which I have received samples for from EspressIf, however I have no idea where to connect it to get all three working concurrently (PICO's Internal Flash, extrenal 3.3V SPRAM, and Micro SD 4-line mode).
qwert1213131
Postby qwert1213131 » Fri Sep 07, 2018 2:39 am
Does anyone know how to connect pico to psram? Which pins are connected?
ESP_Lvxinyue
Postby ESP_Lvxinyue » Mon Sep 17, 2018 3:12 am
You may try the following connection:
PICO <----> PSRAM
SD1 <----> SIO0
SD0 <----> SIO2
CLK <----> SCLK
CMD <----> SIO3
IO17 <----> SIO1
SD2/SD3 <----> CS#
Hope it'd help. Let me know if you have further questions. Thanks.
ESP_Angus
Postby ESP_Angus » Mon Sep 17, 2018 3:50 am
One additional note, if using PSRAM with PICO-D4 make sure the PSRAM uses 3.3V not 1.8V levels. The recently released ESP-PSRAM64H uses 3.3V. The ESP-PSRAM32/ESP-PSRAM64 (without the H) are 1.8V only and not compatible with ESP32-PICO-D4.
egimbernat
Postby egimbernat » Thu Oct 11, 2018 6:32 pm
Is safe to modify IDF like https://github.com/espressif/esp-idf/is ... -417991037?
I don't see a big problem, but I want to make sure is the correct solution
seonroz
Contact:
Postby seonroz » Fri Oct 26, 2018 10:36 pm
ESP_Lvxinyue wrote:Hi,
PICO <----> PSRAM
SD1 <----> SIO0
SD0 <----> SIO2
CLK <----> SCLK
CMD <----> SIO3
IO17 <----> SIO1
SD2/SD3 <----> CS#
Hi, can I just clarify, CS# is that tied to both SD2 and SD3? or either SD2 and SD3?
Thanks,
Seon
unexpectedmaker.com
Seon
unexpectedmaker.com
seonroz
Contact:
Postby seonroz » Sun Oct 28, 2018 9:28 pm
Also, do we need a 10k pull-up on the CE/CS pin? I've seen reference to a pullup on other SPIRAM diagrams on the ESP32, so curious if we need it for the PICO + SPIRAM?
Thanks,
Seon
unexpectedmaker.com
Seon
unexpectedmaker.com
ESP_Lvxinyue
Postby ESP_Lvxinyue » Wed Oct 31, 2018 3:03 am
For your reference, CS# is tied to either SD2 or SD3, and a 10k pull-up is necessary. Thanks.
seonroz
Contact:
Postby seonroz » Wed Oct 31, 2018 3:05 am
Thanks!
Seon
unexpectedmaker.com
Seon
unexpectedmaker.com
Users browsing this forum: Majestic-12 [Bot] and 6 guests
