Hey Guys,
I am trying to develop a mesh network using 6lowpan with ESP32-devkitc v4 board.
It would be really kind if you guys suggest me how to proceed.
I have crawled all the Github but couldn't found any suitable solution.
Now I am not sure, whether I can use this board for 6lowpan or not.
Thanks for helping.
Ankit
Implementation of 6LoWPAN using ESP32-devkitc v4
myesp32demo
Re: Implementation of 6LoWPAN using ESP32-devkitc v4
6lowpan normally is run over 802.15.4, the ESP32 does not support that out of the box (doesn't have the radio for it).
myesp32demo
Thanks a lot for your reply.
Do you have any recommendation of dev board for both Mesh Networking and 6LoWPAN.
I want to compare them using several factors.
- leandro.adonis86
One way possible for now is 6LoWPAN over BLE RFC7668. I did try myself with raspberry pi 3 (with forced ble activated) and it does work. Check out Benjamin Aigner work at https://es.technikum-wien.at/aignerb/es ... 668-public for esp-idf library you need to import BTstack library to inside folder "components" just follow his instructions.
Student of Computer Engineering from Polytechnic Institute of Leiria - Portugal
myesp32demo
Thanks a lot for your input.One way possible for now is 6LoWPAN over BLE RFC7668. I did try myself with raspberry pi 3 (with forced ble activated) and it does work. Check out Benjamin Aigner work at https://es.technikum-wien.at/aignerb/es ... 668-public for esp-idf library you need to import BTstack library to inside folder "components" just follow his instructions.
Users browsing this forum: Bing [Bot], ChatGPT-User, PerplexityBot, Qwantbot and 1 guest
