Bin files still contain assert and code strings
Lucas.Hutchinson
Postby Lucas.Hutchinson » Tue Sep 25, 2018 2:11 am
Hey All,
Trying to get small build binaries, and ultimately byte identical build repeat-ability on different computers, however i am running into some issues.
I have tried to disable all logging, as well as more importantly removing the assert prints using the silent assert mode( and even with assets disabled), However there always still seems to be user readable strings in the built binary.
Eg; the following string can be found in the first 1k of flash in my binaries no matter what options i enable or disable.
esp_task_wdt_init(CONFIG_TASK_WDT_TIMEOUT_S,.true)./home/lucas/esp32.core/lib/esp-idf/components/esp32/./cpu_start.c
As you can see there is still visible user strings in the binary, and more to the point user strings that change depending on where the code is compiled.
Is this a known issue?
Are there any other things that can be done to remove this sort of stuff from the resulting binary?
(Using IDF V3.1)
Lucas.Hutchinson
Re: Bin files still contain assert and code strings
Postby Lucas.Hutchinson » Thu Sep 27, 2018 2:29 am
Bump, @ESP_Angus, any thoughts on this?
It seems to be related to the
ESP_ERROR_CHECK
macro
WiFive
Postby WiFive » Thu Sep 27, 2018 3:37 am
https://github.com/espressif/esp-idf/bl ... #L100-L104
https://github.com/espressif/esp-idf/bl ... #L327-L329
If you have assertions disabled it should not embed these references but it doesn't seem to remove them in silent mode
Angus
Postby Angus » Thu Sep 27, 2018 4:32 am
Hi Lucas,
You're right, the ESP_ERROR_CHECK macro isn't correctly written for "silent" asserts, so these strings still end up in the binary. Will fix.
Angus
Angus
Postby Angus » Thu Oct 04, 2018 1:05 am
This should be fixed in master branch now, since commit 594dcd525. Thanks very much for reporting it.
Users browsing this forum: Applebot, Google [Bot], Semrush [Bot] and 1 guest
