Unable to install PIP future or cryptography on msys32 for windows
hassan789
Postby hassan789 » Tue Sep 25, 2018 7:53 pm
Fresh install of msys32 toolchain on windows
commit: 66fd7e9cc3d5327d94b5bf681100d1e3f2cf73e1
I am unable to install PIP "future" or "cryptography"
already ran:
pip install --upgrade setuptools
python -m pip install --upgrade pip
See attached pic.
Any tips?
File "C:/msys32/mingw32/lib/python2.7/distutils/msvc9compiler.py", line 306, in <module>
        raise DistutilsPlatformError("VC %0.1f is not supported by this module" % VERSION)
    distutils.errors.DistutilsPlatformError: VC 6.0 is not supported by this module
Complete output from command python setup.py egg_info:
        No working compiler found, or bogus compiler options passed to
        the compiler from Python's standard "distutils" module.  See
        the error messages above.  Likely, the problem is not related
        to CFFI but generic to the setup.py of any Python package that
        tries to compile C code.  (Hints: on OS/X 10.8, for errors about
        -mno-fused-madd see http://stackoverflow.com/questions/22313407/
        Otherwise, see https://wiki.python.org/moin/CompLangPython or
        the IRC channel #python on irc.freenode.net.)
Angus
Re: Unable to install PIP future or cryptography on msys32 for windows
Postby Angus » Wed Sep 26, 2018 6:29 am
Hi hassan,
Thanks for raising this. I thought Python would use the prebuilt library in this case, but it seems to be trying to compile one.
Solution is to run this command:
pacman -S mingw-w64-i686-python2-cryptography
Then re-running "pip install -r requirements.txt" will succeed.
Will update the docs and the MSYS2 environment to include this.
hassan789
Postby hassan789 » Wed Sep 26, 2018 3:59 pm
Awesome, that did the trick.
Other than this warning, everything is looking good:
WARNING: Toolchain version is not supported: crosstool-ng-1.22.0-80-g6c4433a5
Expected to see version: crosstool-ng-1.22.0-80-g6c4433a
Milan991
Postby Milan991 » Fri Sep 28, 2018 11:31 am
I've run all the commands that you suggested:
python -m pip install --upgrade setuptools
But after that, when I run:
python -m pip install --user -r D:/esp-idf/requirements.txt
I got a following error:
Command "python setup.py egg_info" failed with error code 1 in c:\users\011lab\appdata\local\temp\pip-install-fxrkmd\future\
What can I do to overcome this error?
Thank you in advance.
Angus
Postby Angus » Mon Oct 01, 2018 5:23 am
Turns out that setuptools has to be installed from MSYS2, not pip. To fix the install, run the two commands mentioned here:
https://github.com/espressif/esp-idf/is ... -425790054
A new MSYS2 image without these problems will be available ASAP.
kenjyminamori
Postby kenjyminamori » Mon Oct 22, 2018 10:40 am
This issue is still opened!
Could you please add reference to tutorial?
Angus
Postby Angus » Tue Oct 23, 2018 3:25 am
Hi kenjy,
Try these commands in this order:
python -m pip uninstall -y setuptools
pacman -S mingw-w64-i686-python2-setuptools mingw-w64-i686-python2-cryptography
python -m pip install -r $IDF_PATH/requirements.txt
(You might get an error from the first command, if setuptools is not installed via pip. As you haven't provided any details, I don't know which error you're getting.)
Alternatively, you can download a newer version of the MSYS2 .zip from here and it should "just work":
https://docs.espressif.com/projects/esp ... hain-setup
arnold.braun@gmx.de
Postby arnold.braun@gmx.de » Thu Mar 28, 2019 5:29 am
Thanks for your post. it helped
filipESP
Postby filipESP » Fri Mar 29, 2019 8:23 am
I have similar problem but the commands above don't resolve it.
Here is my topic: https://www.esp32.com/viewtopic.php?f=13&t=9893
Users browsing this forum: PerplexityBot, Qwantbot and 1 guest
