Is there a recommended way to use pre-compiled user libraries in the SDK? I saw that I can modify the project template Makefile to include my own libraries. But at the moment the linking process fails when I access some functions from this library. I guess there is something wrong with my compiled library. So I wonder the following things:
1. Any recommended compile flags for the esp32?
2. Any recommended way to include binary user libraries into a project except to just modifying the Makefile?
Integrate pre-compiled user libraries
Re: Integrate pre-compiled user libraries
hi
not sure how you mean this,
( translater english-german)
but think have understand, have a try
the bad way would be:
put your own lib ( *.a ) in the RTOS SDK Folder \lib
and expand the makefile with your libname
better way is:
create a new own folder and put there your own libs
then expand the makefile in sektion "search folder"
with your own folder / path
recommend to you an own lib path since the RTOS can change again and again.
you can use the template for make user libs too,
look in the lib-example and create here your lib to your project.
the makefile search here for a lib.
if you use this lib in other projects, then you must put it central as described in the posting start.
hope this helps.
rudi
better way is:
hope this helps.
rudi
- bovensiepen
Thanks rudi. I adapted now my own Makefile. You are right that it is better to handle my library code outside of the RTOS sdk.
Users browsing this forum: Google [Bot], PerplexityBot, Qwantbot, Semrush [Bot], YisouSpider and 6 guests
