In deep sleep mode,Wake up device by triggering IO:
const uint64_t ext_wakeup_pin_mask = (1ULL << 33);
esp_sleep_enable_ext1_wakeup(ext_wakeup_pin_mask, ESP_EXT1_WAKEUP_ALL_LOW);
esp_deep_sleep_start();
i can get evnets ESP_SLEEP_WAKEUP_EXT1,but Call function esp_sleep_get_ext1_wakeup_status(),return 0;
Use high level trigger to get IO number normally.
GPIO as trigger source for wake-up sleep mode,When the wake-up event is triggered, get the pin number is 0.
Re: GPIO as trigger source for wake-up sleep mode,When the wake-up event is triggered, get the pin number is 0.
According to my understanding, because the trigger condition is ESP_EXT1_WAKEUP_ALL_LOW,So I can't judge which pin is triggered。WiFive wrote:https://esp32.com/viewtopic.php?f=14&t=6427
1、In this configuration,the function esp_sleep_get_ext1_wakeup_status always return 0?
2、Suppose I have three trigger pins, how to distinguish?
If you have 3 trigger pins ALL_LOW means all 3 pins have to be low at the same time to wake up, you can't tell in which order they went low. There is no setting for ANY_LOW.
Users browsing this forum: No registered users and 131 guests
