ESP32-CAM with MicroPython
rp346@njit.edu
Postby rp346@njit.edu » Tue Nov 20, 2018 10:08 pm
Hi, I just got ESP32-CAM and was able to flash micropython on it. My main purpose of ESP32-CAM to take pictures.
Anyone knows python lib I can use on ESP32-CAM to access camera ?
thanks
jstephencorey
Re: ESP32-CAM with MicroPython
Postby jstephencorey » Mon Jan 30, 2023 12:47 am
I've been down this hole, and I found the follwing resources:
1. https://github.com/shariltumin/esp32-ca ... ython-2022 has some good instructions for how to flash your firmware, but it's missing a few things.
2. https://iot.stackexchange.com/questions ... to-the-esp this has some good troubleshooting tips, and I needed it to get it to work with the CAM board.
Basically:
Download firmware from here (https://github.com/lemariva/micropython ... r/firmware)
With Thonny closed, add to the configuration.ini file under the [ESP32] section:
dtr = False
rts = False
Open Thonny, flash the firmware, and you're good to go.
Users browsing this forum: Amazon [Bot], ChatGPT-User, PerplexityBot and 3 guests
