could I to generate 40Mhz pulse on esp32 GPIO
NewPrasertKitt
I tried from those codes on Google but seem they doesn't work! Is the esp32 can do that?
best regards
NewPrasertKitt
best regards
NewPrasertKitt
Re: could I to generate 40Mhz pulse on esp32 GPIO
NewPrasertKitt
Rudi, thanks for your kindly help. could you tell me how to code these in arduino.
best regards
NewPrasertKitt
best regards
NewPrasertKitt
Which Board you want use?Rudi, thanks for your kindly help. could you tell me how to code these in arduino.
best regards
NewPrasertKitt
rudi
idahowalker
1 tick on a hardware timer is at 80Mhz. Divide that by two and send it to a GPIO pin. I'd use direct write to the GPIO pin instead of digitalwrite.
https://techtutorialsx.com/2017/10/07/e ... nterrupts/
NewPrasertKitt
Hello rudi,
I did try this sample code and reconfig the timer as below
timer = timerBegin(0, 2, true);
timerAttachInterrupt(timer, &onTimer, true);
timerAlarmWrite(timer, 2, true);
timerAlarmEnable(timer);
I use digitalWrite command to set and reset the GPIO but the pulse output just nothing. How to direct set/reset the GPIO, I think the digitalWrite command is too slow, not fast enough to work at this frequency.
I use Heltec Wifi Kit32 board.
best regards
NewPrasertKitt
best regards
NewPrasertKitt
NewPrasertKitt
hello idahowalker,
could you show me how to code in arduino to direct write GPIO of ESP32. thank you.
best regards
NewPrasertKitt
best regards
NewPrasertKitt
Hi NewPrasertKitt,
The simplest approach is to use on board peripherals to generate the pulse and do not engage the CPUs directly. In this case I propose LED Controller.
Code: Generate-40MHz.ino Select all
#include "driver/ledc.h"
#define PULSE_OUTPUT_PIN 4
void setup()
ledc_timer_config_t ledc_timer;
ledc_channel_config_t ledc_channel;
ledc_timer.speed_mode = LEDC_HIGH_SPEED_MODE;
ledc_timer.timer_num = LEDC_TIMER_0;
ledc_timer.bit_num = (ledc_timer_bit_t) 1;
ledc_timer.freq_hz = 40000000;
ledc_channel.channel = LEDC_CHANNEL_0;
ledc_channel.gpio_num = PULSE_OUTPUT_PIN;
ledc_channel.speed_mode = LEDC_HIGH_SPEED_MODE;
ledc_channel.timer_sel = LEDC_TIMER_0;
ledc_channel.duty = 1;
ledc_timer_config(&ledc_timer);
ledc_channel_config(&ledc_channel);
void loop()
delay(1000);
a small complex arduino example
taken from esp-idf
note:
so i think the rtc_plla_ena is now removed from the lib ..
the example by @krzychb is simple and good and do the things you searched for too.
also the timer example. what you want to do ?
rudi
#include "soc/emac_ex_reg.h"
extern void rtc_plla_ena(bool ena, uint32_t sdm0, uint32_t sdm1, uint32_t sdm2, uint32_t o_div);
// for rev0 chip: f_out = f_xtal * (sdm2 + 4) / (2 * (o_div + 2))
// so for 40MHz XTAL, sdm2 = 1 and o_div = 1 will give 50MHz output
void setup() {
PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO16_U, FUNC_GPIO16_EMAC_CLK_OUT);
REG_SET_FIELD(EMAC_EX_CLKOUT_CONF_REG, EMAC_EX_CLK_OUT_H_DIV_NUM, 0);
REG_SET_FIELD(EMAC_EX_CLKOUT_CONF_REG, EMAC_EX_CLK_OUT_DIV_NUM, 0);
REG_CLR_BIT(EMAC_EX_CLK_CTRL_REG, EMAC_EX_EXT_OSC_EN);
REG_SET_BIT(EMAC_EX_CLK_CTRL_REG, EMAC_EX_INT_OSC_EN);
// this did in the past 50Mhz enabled sig on GPIO
// since the rtc_plla_ena was removed from lib
// not sure how this can be enabled now
rtc_plla_ena(1, 0, 0, 1, 0);
void loop() {
note:
Edit: rtc_plla_ena function signature may change, this function may be removed, you may get eaten by raptors if you use it, etc, etc.
rudi
NewPrasertKitt
rudi, krzychb thanks for your help, I use this pulse signal to test osciloscope bandwidth.
best regards
NewPrasertKitt
best regards
NewPrasertKitt
Users browsing this forum: Qwantbot and 0 guests
