Is there a forecast on esp-idf v3.2 as stable release?
Esp idf V3.2 release date
Re: Esp idf V3.2 release date
Hi davdav,
We don't have a concrete release date. We're currently finalizing a release candidate version, which should be tagged before the end of the year. Then depending on the final round of QA and internal testing a final release will be some days or weeks after this.
Sorry we can't give a more precise release date at this point.
Angus
Angus
Thank you @ESP_Angus. If I need to do some test is it better:ESP_Angus wrote: ↑Tue Dec 18, 2018 3:33 amHi davdav,
Angus
-to checkout branch "release/v3.2"
-or to use tag "v3.2-beta1"?
I'd probably recommend checking out the release branch in this case, as it's so close to RC.
There's some more about updating to a release branch in the docs:
https://docs.espressif.com/projects/esp ... ase-branch
OK @ESP_Angus,
I had a look on document regarding and I will go with release branch.
Thanks!
Thanks!
