Esp32 , OpenOCD ,JTAG Error
arunbm123
Postby arunbm123 » Wed Dec 19, 2018 4:57 am
hello friends
I am debugging esp32 using external JTAG and openoCD
I am using NODEMCU esp32
I am getting following error, Please give me some solution what to do ?
I am able to see JLINK in my device Manager in Windows.
$ bin/openocd.exe -s share/openocd/scripts -f interface/jlink.cfg -f board/esp-wroom-32.cfg
Open On-Chip Debugger 0.10.0-dev (2018-11-05-04:10)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
esp32 interrupt mask on
jaylink: Failed to open device: LIBUSB_ERROR_NOT_SUPPORTED.
Info : No device selected, using first device.
Error: No J-Link device found.
Angus
Re: Esp32 , OpenOCD ,JTAG Error
Postby Angus » Thu Dec 20, 2018 11:04 pm
Windows needs to be configured to use the WinUSB (generic) driver for the J-Link, or it won't be able to see it.
We have similar instructions for the FTDI USB chip on the WROVER-KIT board:
https://docs.espressif.com/projects/esp ... ml#windows
In the case of the JLink, you need to use the same Zadig tool to change the JLink's driver to WinUSB.
(The FTDI has two interfaces, because it does both serial and JTAG, but the JLink USB device probably only has one.)
arunbm123
Postby arunbm123 » Fri Dec 21, 2018 10:52 am
hi
As per your post I configued WinUSB
now I am getting this error..// Hope I am using correct target and interface..I am using NodeMcu esp32 development Kit
renu@arun MINGW32 ~/esp/openocd-esp32
$ bin/openocd.exe -s share/openocd/scripts -f interface/jlink.cfg -f target/esp32.cfg
Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'.
Info : J-Link ARM V8 compiled Nov 28 2014 13:44:46
Info : Hardware version: 8.00
Info : VTarget = 0.000 V
jaylink: JTAG I/O operation failed: 05.
Error: jaylink_jtag_io() failed: JAYLINK_ERR_DEV.
Error: An adapter speed is not selected in the init script. Insert a call to adapter_khz or jtag_rclk to proceed.
Postby Sprite » Sat Dec 22, 2018 5:05 am
Sounds like you're missing a connection between VTref (pin 1 on the 20-pin JTAG connector of the Jlink) and the 3.3V power supply of the ESP32. Make that connection and it should start to work.
arunbm123
Postby arunbm123 » Sat Dec 22, 2018 6:22 am
yes you are Right...loose connection
Now its giving this error
adapter speed: 12000 kHz
Info : clock speed 12000 kHz
newsettler_AI
Postby newsettler_AI » Sat Dec 22, 2018 7:00 pm
I'm facing issue with start debugging under Eclipse...
Command:
bin/openocd -s share/openocd/scripts -f interface/jlink.cfg -f board/esp-wroom-32.cfg
Output:
Info : J-Link ARM / Flasher ARM V4 compiled Aug 23 2018 09:52:26
Info : Hardware version: 4.02
Info : VTarget = 3.314 V
Info : clock speed 20000 kHz
When I'm trying launch debug, here is output in console:
Info : Target halted. PRO_CPU: PC=0x40000400 (active)    APP_CPU: PC=0x40000400
Info : Target halted. PRO_CPU: PC=0x4009171A (active)    APP_CPU: PC=0x40000400
Info : Flash mapping 0: 0x10020 -> 0x3f400020, 36 KB
Info : Flash mapping 1: 0x20018 -> 0x400d0018, 78 KB
Info : Auto-detected flash size 4096 KB
Info : Using flash size 4096 KB
Info : Using flash size 80 KB
Info : Using flash size 40 KB
Warn : negative reply, retrying
Warn : acknowledgment received, but no packet pending
Info : esp32: Debug controller 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : Target halted. PRO_CPU: PC=0x5000004B (active)    APP_CPU: PC=0x00000000
Info : esp32: Core 0 was reset (pwrstat=0x1F, after clear 0x0F).
Info : esp32: Debug controller 1 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 1 was reset (pwrstat=0x5F, after clear 0x0F).
And what I've got in Eclipse:
Debuggin from console starts fine (log):
$ xtensa-esp32-elf-gdb -x gdbinit_ build/hello-world.elf
GNU gdb (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a5) 7.10
Copyright (C) 2015 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "--host=i686-host_pc-mingw32 --target=xtensa-esp32-elf".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from build/hello-world.elf...done.
0x4000941d in ?? ()
JTAG tap: esp32.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
JTAG tap: esp32.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Hardware assisted breakpoint 1 at 0x400d24bb: file C:/Projects/ESP32/Projects/hello_world/main/hello_world_main.c, line 101.
Any ideas where I should dig?..
arunbm123
Postby arunbm123 » Wed Jan 02, 2019 12:12 pm
hello friends
I am getting following error with jtag kindly help
[Codebox]
Info : VTarget = 3.280 V
Error: JTAG scan chain interrogation failed: all zeroes
Error: esp32.cpu0: IR capture error; saw 0x00 not 0x01
[/Codebox]
Edje11
Contact:
Postby Edje11 » Wed Jan 02, 2019 1:36 pm
Have a look at my blog to see how to setup jtag in Sloeber (eclipse)
http://evertdekker.com/?p=1191
arunbm123
Postby arunbm123 » Thu Jan 03, 2019 7:15 am
hello Friends
Thanks to all who supported me.
I am able to debug in ecilpse and as well as on Commad Line.
This issue was solved by connecting power line of esp32 to segger jTag.
Arun
