Suspicious Memory leak when using esp-mqtt
zilizii
Postby zilizii » Tue Jan 22, 2019 9:51 pm
I tries to make a small Home Automation project with a Nextion display. I use Eclipse and C++ with the ESP-IDF together.
I made the first single test with the following code:
void mqtt_app_start(void * parameters)
    esp_mqtt_client_config_t mqtt_cfg = {
    		.event_handle = mqtt_event_handler,
    		.host = "192.168.1.140",
			.uri = "mqtt://192.168.1.140:1883",
			.port = 1883,
			.client_id = "NextionMQTTBridge",
			.username = mqtt_user,
			.password = mqtt_password,
    ESP_LOGI(TAG, "[APP] Free memory: %d bytes", esp_get_free_heap_size());
    esp_mqtt_client_handle_t client = esp_mqtt_client_init(&mqtt_cfg);
    xEventGroupWaitBits(wifi_event_group, CONNECTED_BIT, false,true, 5000 / portTICK_PERIOD_MS);
    esp_mqtt_client_start(client);
    while(1){
    	vTaskDelay(5000 / portTICK_PERIOD_MS);
    	esp_mqtt_client_publish(client,"test/NextionMQTTBridge","Hello World",10,0,0);
    vTaskDelete(NULL);
This is called via following way:
void app_main(void) {
       nvs_flash_init();
       wifi_init();
       xTaskCreate(&mqtt_app_start, "MQTT", 2000,NULL,5,NULL );
       while(1) {
I checked the log file and for me seems a continusly decreasing trend....
Started:
I (12367) NextionMQTTBridge: [APP] Free memory: 213752 bytes
I (2477367) NextionMQTTBridge: [APP] Free memory: 213248 bytes
Where I made the mistake? Thank you very much in advance!
Trial - Error scenario for learning ESP32 :D
zilizii
Re: Suspicious Memory leak when using esp-mqtt
Postby zilizii » Wed Jan 23, 2019 8:38 pm
After a day running seems oscillating
currently the low point the low (82292367) NextionMQTTBridge: [APP] Free memory: 213064 bytes
which is far way from the top:
I (84432367) NextionMQTTBridge: [APP] Free memory: 214876 bytes
And the same "static" code running. I do not except this difference
Angus
Postby Angus » Thu Jan 24, 2019 1:44 am
Because both the TCP/IP stack and the WiFi stack allocate from heap, you can expect some variance in memory usage during network activity. Something in the order of ~1800 bytes between min and max is likely to be expected. If there's no constant decreasing trend then there is no memory leak as such.
Some information about memory leak false positives can be found here:
https://docs.espressif.com/projects/esp ... mory-leaks
To stabilise heap usage from the Wi-Fi stack, there are some configuration items you can choose: set a high number of Static RX buffers, set the number of Dynamic RX buffers to 1, and set TX buffers to static. This will decrease the amount of variability in heap usage, however it will also increase the overall (constant) heap usage. We don't really recommend this unless you plan to push right to the limit of minimum available heap, and can't risk some small allocations.
Unfortunately no similar option exists for TCP/IP.
zilizii
Postby zilizii » Thu Jan 24, 2019 6:04 pm
Thank you for your explanation, good to know. I will read those documents to increase my knowledge.
