Am a bit new to this..
Followed install instructions to clone the IDF:
$ git clone -b v3.1.2 --recursive https://github.com/espressif/esp-idf.git
It ran without errors, however, many directories are missing, for example when I look:
$ ls ../esp-idf/examples/protocols/
aws_iot coap_server http_request https_mbedtls mdns openssl_server README.md udp_multicast
coap_client esp_http_client http2_request https_request openssl_client pppos_client sntp
There is no http_server example or https_server. How do I get these (or everything?)
thanks
git clone not getting everything
Re: git clone not getting everything
Hi twompark,
These examples are not part of ESP-IDF v3.1, which is the current stable release version.
If you check out the v3.2 release branch (git checkout release/v3.2) then it has the http_server example but not https_server.
To get both the https_server and http_server you will need to check out the master branch (git checkout master).
Some explanation about the different version types and branches can be found here: https://docs.espressif.com/projects/esp ... sions.html
Users browsing this forum: Google [Bot], pankaj8at, Timmwardion and 131 guests
