GSM module circuit with ESP32 board
I am using quectal m95 gsm module with esp32 board to create a point to point cellular connection, Can i connect thier TX and RX pins directly or i need to do some volatge level conversions???
Re: GSM module circuit with ESP32 board
Check the datasheets for voltage levels. ESP32 uses 3.3V so if your devices uses the same you should be good to go.
4V logic? Sounds like an odd value. Are you sure about that?
In any case, use a levelshifter, such as the TXB0102DCUR.
You could also use a simple voltage divider based on two resistors for each channel.
Users browsing this forum: djixon, MicroController, ramier and 78 guests
