Esp32 connected to 1-wire overheats and burns board
HI. Im newbie and i have a very few knowledhe of HW. I come from SW. We are trying to connect esp32 to a device implenting 1wire protocol. So 1 pin from esp32 is connected to 1-wire data device. Everything is done and working great.... but i've burnt 6 boards already and it seems that there is no reason at all!. But I suspect that it is because 1-wire data is 5v and of course esp is 3.3. So the question is...is there an easy way to connect an output pin to a 5v device? I have a buck converter just for connect esp32 to 12v/24.... but do i have to add another buck converter to 1wire pin? How?
Re: Esp32 connected to 1-wire overheats and burns board
There's not really enough detail here to give an answer. Exactly what device(s) do you have (what ESP32 board and what is the "1-wire device"), exactly what pins are connected to what? Exactly what power sources are connected to what (and on which pins)
If you can provide photos or a diagram of the connections, someone can probably help you find the problem.
HI. no matter what esp32 i use...because i burnt all of them. I'm connecting esp32 to 12v/24 gps device using a bucket converter (OKI-78SR-3.3). Everything is fine at this point. When connecting one pin from esp32 to a "1-wire data pin" from gps device, which works at 5v, smoke starts appearing. The problem is that sometimes it takes a lot for smoke to appear...so that is why i realized so late of this fact (and of course because i'm absolutely a newbie).
So the product pointed by WiFive about "Bi-Directional Logic Level Converter" seems to be a good solution... i will test it tomorrow. But my question is now: is it mandatory to connect "HV" and "GND" from gps device? i mean...it will be enough just to connect any of "HVX" and "GNDX"? gps device has "1wire power" and "1wire data" pins. I dont know if i will have to use both of them or just with "1wire data" will be engough. For i-button it is only neede 1wire data (no 1wire power)
I really appreciate any comments before i burn my house with all my family inside.
Thank you
Thank you
Hi slluch,
There still isn't enough information in your post for someone to help you. You mention a number of pin names but you haven't mentioned the model number of the GPS device you are using, so noone can help you. A good picture of your setup will help a lot.
Angus
Angus
Hi. finally this is the solution. thank you very much!
finally chegewara got the solution with logic level converter. thank you!!
Users browsing this forum: Bing [Bot] and 2 guests
