ESP32 5GHz
Re: ESP32 5GHz
Postby Sprite » Tue Mar 05, 2019 11:47 am
Gotcha. FWIW, this has some priority in our development roadmap as you're not the only customer asking for this, but unfortunately it takes a while to design and tapeout the hardware.
Deouss
Re: ESP32 5GHz
Postby Deouss » Tue Mar 05, 2019 1:13 pm
Will this new board feature new Esp chip maybe 64 bit or it will be the current wroom/wrover architecture?
Re: ESP32 5GHz
Postby Sprite » Wed Mar 06, 2019 7:09 am
Can't say, but what advantages would you see in a 64-bit CPU? There's really not much use for >4GiB of RAM in an embedded microcontroller-like architecture like the ESP32.
Deouss
Re: ESP32 5GHz
Postby Deouss » Wed Mar 06, 2019 12:53 pm
64bit would help with FPU calculations and camera stuff a lot. Any video capture of larger images like HD needs powerful cpu.
More memory is a good thing and very needed and demanded today)
Re: ESP32 5GHz
Postby Sprite » Fri Mar 08, 2019 8:38 am
Erm... I still fail to see the use. There's no relationship between the CPUs addressing width and the FPU width; it's perfectly possible to bolt a double-precision FPU to a 32-bit machine. Same for the processing power: 64-bit doesn't immediately mean a faster CPU (it even may mean a slower CPU, depending on your architecture.) Furthermore, 64-bit integer calculations can be useful, but only if you can use them in a VLIW way, and in that case, something like a vector processor may be a better addition. And sure, more memory is more better, but the ESP32 is at 8MiB or so now; a long way away from the 4GiB that's the limit for 32-bit processors.
Deouss
Re: ESP32 5GHz
Postby Deouss » Fri Mar 08, 2019 2:03 pm
Well, good points - so are they going to improve current architecture so we could access more than 8Mb of PSRAM or any ram as continuous memory blocks?
Can they embed large amount of internal fast RAM to the chip? Maybe 32Mb or more
Also PLL oscillator/synthesizer - maybe it can be improved to get faster clocks for peripherals like 100-300MHz outputs
Re: ESP32 5GHz
Postby Sprite » Fri Mar 08, 2019 8:17 pm
Sounds like useful suggestions, but maybe we're better off moving this discussion to https://www.esp32.com/viewtopic.php?f=2&t=2772 .
borayildizme
Re: ESP32 5GHz
Postby borayildizme » Thu Aug 08, 2019 3:14 pm
It seems new chip is coming soon. As I followed in Twitter there will be no 5Ghz in first version. Could anyone share the roadmap or estimated release date of 5Ghz supported version?
Thanks,
Bora
bobo1974
Re: ESP32 5GHz
Postby bobo1974 » Tue Nov 19, 2019 12:11 pm
I also absolutely need 5ghz in my next product revision. We use the chip to sense the WiFi environment.
Do you have an estimate of if/when this will come? Esp_sprite was mentioning end of 2019 initially.
Ben
Re: ESP32 5GHz
Postby Sprite » Thu Nov 21, 2019 10:00 am
Yup. We won't be able to make it this year, we hope to have the first beta silicon out in the first half of 2020. (Note that this is still an estimate, standard disclaimer applies: don't count on estimates, plans can slip, your mileage may vary, offer not valid in all states, handwash only and keep away from sunlight.)
Users browsing this forum: ChatGPT-User, Qwantbot, Semrush [Bot] and 4 guests
