ESP32 TFT display library
Deouss
Re: ESP32 TFT display library
Postby Deouss » Thu Aug 02, 2018 3:16 pm
Is there some register call to wait for Vsync ?
I am getting tearing effect after spi loads full tft frame
jstoefer
Postby jstoefer » Tue Nov 27, 2018 4:06 pm
since I am interested in using a ILI9341-based TFT with 3-wire IF, how is the state of support for 3-wire ?
Greetings, Jan
devleon
Postby devleon » Mon Feb 11, 2019 12:49 am
JanJansen47 wrote:
Tue Jun 20, 2017 12:29 pm
I measured the signals with a scope and found a strange signal on the SDO from TFT and Touch (same line). I disconnected the SDO connection from the TFT and directly wired it to the Touch.
At least TFT and touch is working for now. ;) But it does not feel okay. So I ask the supplier.
My wiring is available on request.
Please share your wiring with us, as the poster before mentioned, it isn't quite clear what was meant.
I have a ER-TFTM035-6 and the touch also just doesn't seem to work. It only works when I disconnect SLC, SDO and SDI from the TFT completely. But then I have no tft, only touch.
ltbeck
Postby ltbeck » Thu Mar 14, 2019 2:02 pm
I’m experimenting with this library using a ESP32 Pico kit v4.1 and this touchscreen TFT panel: https://raw.githubusercontent.com/lobor ... li9341.jpg
I have it hooked up this way:
• mosi: 23
• miso: 19
• sck: 18
• CS: 5 (display CS)
• DC: 26 (display DC)
• TCS: 25 (touch screen CS)
Reset and LED are tied high. MISO and MOSI are shared with T_DO and T_DI.
All of the TFT functions work great (displays the JPEGs, etc.) but the touch does not work, i.e using demo and a stylus, nothing appears on the screen. I’ve thrown in a few “printf’s” to see if the touch is detected and it appears that it is not.
Any hints?
Thanks,
Lance
chegewara
Postby chegewara » Fri Mar 15, 2019 6:01 am
I would like to thank @loboris for this library. Its easy to use and with it i build a toy for my autistic 3 years old nephew.
Recently i bought m5stack and since my nephew loves colors, numbers and read words he already knows i decided to use it.
Each button is generating random value and display it on screen:
- button 1 for colors, he knows colors in at least 3 languages,
- button 2 for numbers in range 0-100, he knows it in 2 languages already,
- button 3 for random words from preconfigured in app, for now i am using only Polish words, even if he knows words in other languages too.
Its very simple educational toy and he is very happy with it, thanks again.
huybk213
Postby huybk213 » Fri Jun 14, 2019 5:07 am
Hi every one,
I'm using ESP32 TFT display library with ST7789 driver.
But color was invert, for example when i call function TFT_fillWindow(TFT_BLACK) , the screen is WHITE, and TFT_fillWindows(TFT_RED) the screen is green.
I don't know why this problem happen.
jeremyjh
Postby jeremyjh » Thu Sep 26, 2019 10:32 pm
@huybk213 Hopefully you figured it out, but for anyone else you just need to change the RGB settings; by default it uses GBR, to change to RGB in tftspi.h
#define TFT_RGB_BGR 0x00
I also wanted to mention, anyone who wants to use this library with the 4.0 release branch, my fork supports this and also supports making all of these common config changes through menuconfig; so you can use that to set your controller, RGB options, touch mode etc. I also consolidated the open PRs in this branch.
https://github.com/jeremyjh/ESP32_TFT_library
