example of HTTP server in AP mode?
marchingband
Postby marchingband » Wed Mar 13, 2019 9:28 pm
Can anyone direct me to a working example of a simple HTTP server, which uses AP mode?
It seems like a powerful feature of ESP32 but I havn't been able to locate a working example yet.
I would like to be able to connect to the ESP32 network on another device, open a web browser, navigate to some address, and have ESP32 serve a webpage from its flash memory.
karlo.verde.13
Contact:
Re: example of HTTP server in AP mode?
Postby karlo.verde.13 » Fri Mar 15, 2019 9:50 pm
Hey there!
This link shows a tutorial about what you are looking for: http://www.lucadentella.it/en/2018/01/2 ... ta-softap/. Nevertheless, this example uses the Netconn API.
If you want to use the esp_http_server.h component, there is no example implemented with SoftAp, yet.
bluesensing
Postby bluesensing » Sun Mar 17, 2019 9:06 am
i am also very keen on such an working example. reading html from a sdcard
regards from berlin
gerhard
karlo.verde.13
Contact:
Postby karlo.verde.13 » Mon Mar 18, 2019 10:37 am
Hey there!
Since there is no example of what you are looking for, I decided to create one.
NOTES
  • Some header files are unnecessary.
  • This example also includes IP configuration.
  • The URI handler has minimal code in this example but you can define it as you wish.
  • If you have an Android device, I recommend that you use this app: https://play.google.com/store/apps/deta ... tprequests.
  1. #include "string.h"
  2.
  3. #include "freertos/FreeRTOS.h"
  4. #include "freertos/task.h"
  5. #include "freertos/event_groups.h"
  6. #include "esp_wifi.h"
  7. #include "esp_system.h"
  8. #include "esp_event.h"
  9. #include "esp_event_loop.h"
  10. #include "esp_log.h"
  11. #include "nvs_flash.h"
  12. #include "esp_http_server.h"
  13.
  14. #define SOFT_AP_SSID "ESP32 SoftAP"
  15. #define SOFT_AP_PASSWORD "Password"
  16.
  17. #define SOFT_AP_IP_ADDRESS_1 192
  18. #define SOFT_AP_IP_ADDRESS_2 168
  19. #define SOFT_AP_IP_ADDRESS_3 5
  20. #define SOFT_AP_IP_ADDRESS_4 18
  21.
  22. #define SOFT_AP_GW_ADDRESS_1 192
  23. #define SOFT_AP_GW_ADDRESS_2 168
  24. #define SOFT_AP_GW_ADDRESS_3 5
  25. #define SOFT_AP_GW_ADDRESS_4 20
  26.
  27. #define SOFT_AP_NM_ADDRESS_1 255
  28. #define SOFT_AP_NM_ADDRESS_2 255
  29. #define SOFT_AP_NM_ADDRESS_3 255
  30. #define SOFT_AP_NM_ADDRESS_4 0
  31.
  32. #define SERVER_PORT 3500
  33. #define HTTP_METHOD HTTP_POST
  34. #define URI_STRING "/test"
  35.
  36. static httpd_handle_t httpServerInstance = NULL;
  37.
  38. static esp_err_t methodHandler(httpd_req_t* httpRequest){
  39.     ESP_LOGI("HANDLER","This is the handler for the <%s> URI", httpRequest->uri);
  40.     return ESP_OK;
  41. }
  42.
  43. static httpd_uri_t testUri = {
  44.     .uri       = URI_STRING,
  45.     .method    = HTTP_METHOD,
  46.     .handler   = methodHandler,
  47.     .user_ctx  = NULL,
  48. };
  49.
  50. static void startHttpServer(void){
  51.     httpd_config_t httpServerConfiguration = HTTPD_DEFAULT_CONFIG();
  52.     httpServerConfiguration.server_port = SERVER_PORT;
  53.     if(httpd_start(&httpServerInstance, &httpServerConfiguration) == ESP_OK){
  54.         ESP_ERROR_CHECK(httpd_register_uri_handler(httpServerInstance, &testUri));
  55.     }
  56. }
  57.
  58. static void stopHttpServer(void){
  59.     if(httpServerInstance != NULL){
  60.         ESP_ERROR_CHECK(httpd_stop(httpServerInstance));
  61.     }
  62. }
  63.
  64. static esp_err_t wifiEventHandler(void* userParameter, system_event_t *event) {
  65.     switch(event->event_id){
  66.     case SYSTEM_EVENT_AP_STACONNECTED:
  67.         startHttpServer();
  68.         break;
  69.     case SYSTEM_EVENT_AP_STADISCONNECTED:
  70.         stopHttpServer();
  71.         break;
  72.     default:
  73.         break;
  74.     }
  75.     return ESP_OK;
  76. }
  77.
  78. static void launchSoftAp(){
  79.     ESP_ERROR_CHECK(nvs_flash_init());
  80.     tcpip_adapter_init();
  81.     ESP_ERROR_CHECK(tcpip_adapter_dhcps_stop(TCPIP_ADAPTER_IF_AP));
  82.     tcpip_adapter_ip_info_t ipAddressInfo;
  83.     memset(&ipAddressInfo, 0, sizeof(ipAddressInfo));
  84.     IP4_ADDR(
  85.         &ipAddressInfo.ip,
  86.         SOFT_AP_IP_ADDRESS_1,
  87.         SOFT_AP_IP_ADDRESS_2,
  88.         SOFT_AP_IP_ADDRESS_3,
  89.         SOFT_AP_IP_ADDRESS_4);
  90.     IP4_ADDR(
  91.         &ipAddressInfo.gw,
  92.         SOFT_AP_GW_ADDRESS_1,
  93.         SOFT_AP_GW_ADDRESS_2,
  94.         SOFT_AP_GW_ADDRESS_3,
  95.         SOFT_AP_GW_ADDRESS_4);
  96.     IP4_ADDR(
  97.         &ipAddressInfo.netmask,
  98.         SOFT_AP_NM_ADDRESS_1,
  99.         SOFT_AP_NM_ADDRESS_2,
  100.         SOFT_AP_NM_ADDRESS_3,
  101.         SOFT_AP_NM_ADDRESS_4);
  102.     ESP_ERROR_CHECK(tcpip_adapter_set_ip_info(TCPIP_ADAPTER_IF_AP, &ipAddressInfo));
  103.     ESP_ERROR_CHECK(tcpip_adapter_dhcps_start(TCPIP_ADAPTER_IF_AP));
  104.     ESP_ERROR_CHECK(esp_event_loop_init(wifiEventHandler, NULL));
  105.     wifi_init_config_t wifiConfiguration = WIFI_INIT_CONFIG_DEFAULT();
  106.     ESP_ERROR_CHECK(esp_wifi_init(&wifiConfiguration));
  107.     ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_AP));
  108.     wifi_config_t apConfiguration = {
  109.         .ap = {
  110.             .ssid = SOFT_AP_SSID,
  111.             .password = SOFT_AP_PASSWORD,
  112.             .ssid_len = 0,
  113.             //.channel = default,
  114.             .authmode = WIFI_AUTH_WPA2_PSK,
  115.             .ssid_hidden = 0,
  116.             .max_connection = 1,
  117.             .beacon_interval = 150,
  118.         },
  119.     };
  120.     ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_AP, &apConfiguration));
  121.     ESP_ERROR_CHECK(esp_wifi_set_storage(WIFI_STORAGE_RAM));
  122.     ESP_ERROR_CHECK(esp_wifi_start());
  123. }
  124.
  125. void app_main(void){
  126.     launchSoftAp();
  127.     while(1) vTaskDelay(10);
  128. }
Hope it helps
Best regards
Verde :mrgreen:
marchingband
Postby marchingband » Mon Mar 25, 2019 8:22 pm
Amazing. Thanks so much Verde!
phatpaul
Postby phatpaul » Mon Apr 01, 2019 4:39 pm
Here's a http server working out of the box. Lot's of features and examples.
https://github.com/chmorgan/esphttpd-freertos
marchingband
Postby marchingband » Thu Sep 12, 2019 6:35 pm
unfortunately the suggestions above do not work for esp-idf version 4.
Is anyone able to suggest code to run a softAP http server in v4.1?
or perhaps able to port the code?
stock86c
Postby stock86c » Fri Sep 13, 2019 1:28 am
hi
cant share the code, so i will just explain the concepts to get it to work. Literally just slapped these two examples together.
https://github.com/espressif/esp-idf/tr ... ted/softAP
https://github.com/espressif/esp-idf/tr ... ver/simple
as for the "ESP_ERROR_CHECK(example_connect());" in the main of simple httpserver, just replace this example_connect with the init_softAP function from the softAP example. Some points to note:
1.Try to put all the functions in one page. somehow the definitions in different pages seem to cause issues.
2. Use the default settings, the ssid and passwd. Dont do fancy stuffs yet.
3. after combining and compiling, try to solve the errors one by one.
hope it helps.
Users browsing this forum: No registered users and 19 guests
