Hi WiFive
in advance:
Cause the name
Chip7 2-2-A
i think there was a few month ago where few "engineer samples" are tested at espressif
cause
here you find a hint :
"/home/cff/gittree/chip7.1_phy/chip_7.1/board_code/app_test/pp/phy/phy_chip_v7_ana.c"
also it can be mean, that we talk about the IP 7 ( RiscV ), 64Bit, 8 core, 5-6 Pipes,
Atomic,
Linux compatible and further more
i think it is a preview thing ( 2..4 core .. but i can image that is a 64 bit.. )
i think we are very flexible in this, cause it looks like we can configure each 47 IO 's like we want and need.
- 3.png (72.36 KiB) Viewed 20480 times
I think we get 5 GHz -
i think over the name at the bottom, UO0AN5V280, there are few infos perhabs in this?
U 64 Bit
O ??
0 ??
A Atomic
N Normal Mode no compressed for code density
5 5 stage variable pipeline
V Risc-
V
2 Dual Core, Dual Wifi, Dual Wifi & BT/BLE
8 8 Core ?? 8 Mbit eMbeddedFlash ?? 8 MByte eMbeddedFlash ?? .. 8 mm package ??
0 ( No eMbedded Flash ?? )
Not quite sure looking at picture - but is the chip size 2x bigger?
More cores? )
- 8mm.jpg (219.44 KiB) Viewed 20480 times
we drill and keep looking further
rudi
