Which version of these two 3.3 branches of the IDF is the most recent and up to date?
v3.3-dev-278, or v3.3-beta1-223?
And can someone please tell me what the difference between "-dev" and "-beta1" is so that I can figure these things out for myself?
And I've just discovered there is a v3.3-beta2. After it "comes out of beta", what version number does it become?
Is there such a thing a stable release on the v3.3 branch?
I'm looking for the most stable version of v3.3 that doesn't involve me having to make the jump to v4.0
--- Doug
Which version of the 3.3 branch is most recent
DouglasWWolf
fivdiAtESP32
Re: Which version of the 3.3 branch is most recent
I'm not sure where the numbers 278 and 223 are from but the esp-idf git repository has two tags called v3.3-dev and v3.3-beta1. v3.3-beta1 is newer than v3.3-dev. All the tags for the esp-idf repository can be seen at https://github.com/espressif/esp-idf/tags. The tags are listed in chronological order, newest first.
To me, it looks like the esp-idf developers create a tag with the suffix "-dev" on the day they start developing a new version. The tag v3.3-dev was created on November 1st 2018, so I guess v3.3 development started on this day.
Probably v3.3-rc1 for the first v3.3 release candidate.
Not yet.
That would be v3.3-beta2.
Hi Doug,
I think Fivdi has covered most of your individual questions, but I'll add a couple more details:
- There is a page in the docs here which has a description of the different kind of IDF versions, branches, etc: https://docs.espressif.com/projects/esp ... sions.html . Please let me know if any information is missing from there.
- If I check out the "release/v3.3" branch from GitHub and do "git describe --tags" then I get:
This means this branch (the "v3.3 release branch") has had 116 commits since "v3.3-beta2" tag was taken.
So if you want to use a v3.3 prerelease, you can either take "v3.3-beta2" or take the "release/v3.3" release branch which has fixes applied since v3.3-beta2. Probably a v3.3-beta3 will be tagged soon (testing is ongoing for this version.)
If you want the latest stable release, at this time it is v3.1.3. But we'll be tagging a v3.2 Release Candidate this week, hopefully to be followed by the actual release. Check the GitHub Release page for that.
$ git describe --tags
v3.3-beta2-116-g37e131f76
DouglasWWolf
Fivdi & Angus,
Thanks for helping me get up to speed on versioning
--- Doug
--- Doug
Users browsing this forum: Bing [Bot] and 1 guest
