Internet Access
ChapsF
Internet Access
Postby ChapsF » Wed Apr 24, 2019 12:38 pm
Hello, i'm having problem connecting external ip while using Mesh from a second layer.
The mesh network seam to work correctly, what i want is to get the dateTime from internet through NtpClient. When i get the time from the root it work, but it doesn't when trying to get it from a child node. Maybe i'm misunderstanding Mesh, i though i would be able to access internet from any node in the network while not changing the way i do it.
Could anyone point me to a good way to use NtpClient in a mesh network pls? Can anyone give me an exemple of how we should (for exemple) send a Get request and receive the answer from a node that is not root?
Thank you
ESP_yudong
Re: Internet Access
Postby ESP_yudong » Wed Apr 24, 2019 12:54 pm
Hi ChapsF,
Non-root nodes do not have ip address and do not support TCP and UDP.
I think that's why NtpClient doesn't work.
ChapsF
Re: Internet Access
Postby ChapsF » Wed Apr 24, 2019 1:18 pm
Hoo, ok... i though the main purpose of Mesh was to simulate this. Accordinately to this pictures : Image it seam that we can.
Then the Mesh is only* thing that manage "Who is connected to internet" and "give access from any node to the root"?
*[only] it's already something helpfull.
[EDIT] In fact in the picture we can see that in the "Root" the flow go through the application, soo yes we should do this ourself, thank you for your answer.
Users browsing this forum: No registered users and 25 guests
