I have used starting code from issue #632 on the ESP32 Snippets Repo and based on suggestions there, I have managed to achieve quite a bit in my application. I searched through the issues list(both open and closed) but I could not find this or a similar issue reported. I have already reported the issue, have got a response, but that did not solve the problem for me, so I am trying my luck here.
What I am trying to get to is to build a ESP Composite Device ( over GATT), which consists of Two Independent Joysticks at least. These are to support two players.
Based on https://eleccelerator.com/tutorial-abou ... scriptors/, it is possible to create two independent joysticks using two reports.It is also possible that the report map may have a mouse and a keyboard and it will show up additional devices. But the site description is generic, and mostly talks about a USB cable based wired connection versus a BLE HID connection.
I have my code for perusal here https://github.com/rupin/ESPJoystick/bl ... ble632.ino
You will notice I have two reports in my code
const uint8_t reportMap[] = {
0x05, 0x01, // USAGE_PAGE (Generic Desktop)
0x09, 0x04, // USAGE (Game Pad)
0xa1, 0x01, // COLLECTION (Application)
0x85, 0x01, // REPORT_ID (1)
0x05, 0x09, // USAGE_PAGE (Button)
0x19, 0x01, // USAGE_MINIMUM (Button 1)
0x29, 0x10, // USAGE_MAXIMUM (Button 16)
0x15, 0x00, // LOGICAL_MINIMUM (0)
0x25, 0x01, // LOGICAL_MAXIMUM (1)
0x95, 0x08, // REPORT_COUNT (8)
0x75, 0x02, // REPORT_SIZE (2)
0x81, 0x02, // INPUT (Data,Var,Abs)
//0xa1, 0x00, // COLLECTION (Physical)
0x09, 0x30, // USAGE (X)
0x09, 0x31, // USAGE (Y)
0x25, 0xFF, // LOGICAL_MAXIMUM (100)
0x75, 0x08, // REPORT_SIZE (8)
0x95, 0x02, // REPORT_COUNT (2)
// 0xc0, // END_COLLECTION
0x85, 0x02, // REPORT_ID (2)
0x09, 0x33, // USAGE (X)
0x09, 0x34, // USAGE (Y)
0xc0 // END_COLLECTION
};I am sending the data independently using two individual report notifications.
uint8_t a[] = {lButtonState, 0x00, X_Joystick, Y_Joystick};
device1->setValue(a, sizeof(a));
device1->notify();
uint8_t b[] = {0x00, lButtonState, X_Joystick, Y_Joystick};
device2->setValue(b, sizeof(b));
device2->notify();What am I doing wrong?
Reponse from chegewara ( i tried this but it still shows up as a single joystick)
Try removing second USAGE_PAGE or even all 3:
