I did not know where to ask this question, therefore I came here.
Recently I bought multiple ESP32 devices like these: https://www.ebay.com/itm/WEMOS-ESP32-Wi ... ctupt=true and I starting looking into IPS (Indoor Positioning Systems). After a few days of research I found out that this device easily supports BLE communication and distance measurements using RSSI. Althouth, I couldn't find any other localization methods which could be used without attaching some additional components/sensors. Am I missing something? I'm new to IoT so I don't know much about these things.
Is it possible to implement, for example, ToA or TDoA methods in Arduino studio using the previously mentioned ESP32 model?
(maybe NTP is the solution?)
If yes, could you please suggest some functions, libraries or tutorials which could help me ?
Best regards,
Ed
ESP32 possible localization algorithms using no additional components
Edgars Sturms
Re: ESP32 possible localization algorithms using no additional components
ESP-IDF supports getting back CSI information, which means you can figure out things wrt the different phase groups. I'm not sure if anyone already fleshed it out into a fully-functional positioning algorithm or what the precision of that would be, but that is another avenue of investigation you could do.
Edgars Sturms
Thanks for the reply! First time hear about CSI information, on my way to search about it.ESP-IDF supports getting back CSI information, which means you can figure out things wrt the different phase groups. I'm not sure if anyone already fleshed it out into a fully-functional positioning algorithm or what the precision of that would be, but that is another avenue of investigation you could do.
