Can I flash without using PIN34, 35?
jollytopper
I would like to map 34,35 to UART2 RX/TX and use 2, 15 for UART0 RX/TX (flashing, monitor). Is this possible?
Re: Can I flash without using PIN33, 34?
No, not for initial flash. The pins can't be reconfigured that early in the boot process. Also what hardware pin numbering are you referencing?
jollytopper
Sorry I was inconsistent with my naming. I am referencing the IO numbers as per pages 3 and 4 of https://www.espressif.com/sites/default ... eet_en.pdf.
For 34 - RXT0 / 35 - TXD0, I was referencing the Pin Number.
How may I use RXT0/TXD0 as an UART?
jollytopper
# define ATE_RX_PIN 3
# define ATE_TX_PIN 1
uart_set_pin(UART_NUM_2, ATE_TX_PIN, ATE_RX_PIN, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
You can, but you can't change pins for flashing in download boot mode.
jollytopper
I'm not reading any input from my UART when using PINS 34, 35, corresponding to IO 3 and IO 1 respectively.
Users browsing this forum: Perplexity-User and 4 guests
