Hello everyone,
I am using esp_http_client librairy to post data to server.
please refer following link, I am using same code given in link.
https://www.esp32.com/viewtopic.php?f=2&t=8102#p34049
I am stucked in this issue from very long time. not getting any solution or no response from forum for this issue.
I am using esp-idf v3.1.2 stable version, it does not include async mode in the librairy.
Please give me solution as early as possible.
Thanks,
somesh
esp_http_client_perform blocks the task
burkulesomesh43
Re: esp_http_client_perform blocks the task
Hey, Did you face a similar issue with master branch, and can you send us the log with debug enabled?
burkulesomesh43
Actually the API used for post request is blocking API. I think there is only solution to use async.Hey, Did you face a similar issue with master branch, and can you send us the log with debug enabled?
Somesh Burkule
Somesh Burkule
Users browsing this forum: Baidu [Spider], Bing [Bot] and 2 guests
