#include <SD.h>
#include <SPI.h>
#include <BluetoothSerial.h>
BluetoothSerial SerialBT;
int key;
#define SD_CS 34
void setup()
Serial.begin(115200);
SerialBT.begin("ESP32");
SD.begin(SD_CS);
if(!SD.begin(SD_CS)) {
Serial.println("Card Mount Failed");
return;
uint32_t cardType = SD.cardType();
if(cardType == CARD_NONE) {
Serial.println("No SD card attached");
return;
Serial.println("Initializing SD card...");
if (!SD.begin(SD_CS)) {
Serial.println("ERROR - SD card initialization failed!");
return; // init failed
File file = SD.open("data.txt");
if(!file) {
Serial.println("File doens't exist");
Serial.println("Creating file...");
writeFile(SD, "data.txt", "data \r\n");
else {
Serial.println("File already exists");
file.close();
void loop()
int value =0;
int D0 = digitalRead(2);
int D1 = digitalRead(15);
int D2 = digitalRead(4);
int D3 = digitalRead(16);
int D4 = digitalRead(17);
int D5 = digitalRead(5);
int D6 = digitalRead(18);
int D7 = digitalRead(19);
char val[256];
snprintf(val , sizeof(val) , "%d %d %d %d %d %d %d %d",
D0,D1,D2,D3,D4,D5,D6,D7);
Serial.println(val);
appendFile(SD, "data.txt", val);
byte Date[8];
Date[0] = D0;
Date[1] = D1;
Date[2] = D2;
Date[3] = D3;
Date[4] = D4;
Date[5] = D5;
Date[6] = D6;
Date[7] = D7;
readFromAPP();
if(key == 65)
SerialBT.write('B');
for(int i=0;i<8;i++)
SerialBT.write(Date[i]);
delay(10);
key = 0;
delay(100);
void readFromAPP()
while (SerialBT.available() > 0)
key = SerialBT.read();
void appendFile(fs::FS &fs, const char * path, const char * message) {
Serial.printf("Appending to file: %s\n", path);
File file = fs.open(path, FILE_APPEND);
if(!file) {
Serial.println("Failed to open file for appending");
return;
if(file.print(message)) {
Serial.println("Message appended");
} else {
Serial.println("Append failed");
file.close();
void writeFile(fs::FS &fs, const char * path, const char * message) {
Serial.printf("Writing file: %s\n", path);
File file = fs.open(path, FILE_WRITE);
if(!file) {
Serial.println("Failed to open file for writing");
return;
Serial.println("File written");
} else {
Serial.println("Write failed");
file.close();
}This is my code. I want to let 8 pin state through Bluetooth transmission and recording with SD card.
I have been unable to write the data [val] into my SD card.
I connected the CS to pin 34 .
The program is compiled without problems, but I have been unable to write my data [val] to the SD card.
I want to know why and how to modify
