I'm working with ESP-WROVER-KIT V4.1 board in Windows 10.
I follow all the step of the Get Started guide: https://docs.espressif.com/projects/esp ... index.html
I can make flash, make monitor of the hello world example.
I want to use CLION but when I set up it I get this error:
"O:\JetBrains\CLion 2019.1.4\bin\cmake\win\bin\cmake.exe" -DCMAKE_BUILD_TYPE=Debug -DCMAKE_MAKE_PROGRAM=O:/msys32/usr/bin/make.exe -DCMAKE_C_COMPILER=O:/msys32/opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe -DCMAKE_CXX_COMPILER=O:/msys32/opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-c++.exe -DCLION= -G "CodeBlocks - MinGW Makefiles" O:\msys32\home\Pablo\esp\hello_world
-- The C compiler identification is GNU 5.2.0
-- Check for working C compiler: O:/msys32/opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: O:/msys32/opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe -- broken
CMake Error at O:/JetBrains/CLion 2019.1.4/bin/cmake/win/share/cmake-3.14/Modules/CMakeTestCCompiler.cmake:60 (message):
The C compiler
"O:/msys32/opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe"
is not able to compile a simple test program.
It fails with the following output:
Change Dir: O:/msys32/home/Pablo/esp/hello_world/cmake-build-debug/CMakeFiles/CMakeTmp
Run Build Command(s):O:/msys32/usr/bin/make.exe cmTC_eb69b/fast
/usr/bin/make -f CMakeFiles\cmTC_eb69b.dir\build.make CMakeFiles/cmTC_eb69b.dir/build
make: *** [Makefile:120: cmTC_eb69b/fast] Error 1
CMake will not be able to correctly generate this project.
CMakeLists.txt:2 (project)
The problem I'm sure is at:
CMakeFiles\cmTC_eb69b.dir\build.make hte \ should be / but i do'nt know where can I change this setting.
Here is my Settings:
CLion compilation
pablourbano
Return to “General Discussion”
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- ESP32-S31
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- ESP32-S31 中文讨论版
- 喵伴 中文讨论版
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
Users browsing this forum: DuckDuckGo [Bot] and 6 guests
- All times are UTC
- Top
- Delete cookies
About Us
Information
