$ make erase_flash flash
/bin/sh: 第 0 行
Toolchain path: /opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
Toolchain version: crosstool-ng-1.22.0-80-g6c4433a5
Compiler version: 5.2.0
Python requirements from D:/xxxx/esp/esp-mdf/esp-idf/requirements.txt are satisfied.
Erasing entire flash...
esptool.py v2.6
Serial port COM7
Connecting....
Chip is ESP32D0WDQ5 (revision 1)
MAC: 24:6f:28:f0:09:68
Uploading stub...
Running stub...
Stub running...
Erasing flash (this may take a while)...
Chip erase completed successfully in 8.8s
Hard resetting via RTS pin...
Flashing binaries to serial port COM7 (app at offset 0x10000)...
esptool.py v2.6
Serial port COM7
Connecting.....
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Compressed 8192 bytes to 31...
Wrote 8192 bytes (31 compressed) at 0x0000d000 in 0.0 seconds (effective 5486.9 kbit/s)...
Hash of data verified.
Compressed 23136 bytes to 13703...
Wrote 23136 bytes (13703 compressed) at 0x00001000 in 1.2 seconds (effective 152.7 kbit/s)...
Compressed 1455344 bytes to 884093...
Wrote 1455344 bytes (884093 compressed) at 0x00010000 in 78.1 seconds (effective 149.1 kbit/s)...
Compressed 3072 bytes to 162...
Wrote 3072 bytes (162 compressed) at 0x00008000 in 0.0 seconds (effective 1071.4 kbit/s)...
Leaving...
另外的一个始终无法再次烧写成功的开发板提示异常信息如下:
/bin/sh: 第 0 行
esptool.py v2.6
Serial port COM7
Connecting........_____....._____....._____....._____....._____....._____....._____
make: *** [/d/xxxx/esp/esp-mdf/esp-idf/components/esptool_py/Makefile.projbuild:78:erase_flash] 错误 2
我烧写的固件是mdf中的liht的例程,烧写方法与固件类型所有的8个开发板都一样的,但是不知道为什么有一个开发板会出问题,希望帮我解决下这个问题,少一个开发板组网时一直无法看到变化后的组网新形式
