Folks,
I'm having trouble debugging using esp-prog, and an esp32_core_board on linux.
when I run openocd (prebuilt), I get:
user1@NUCi7Linux ~/esp/openocd-esp32 $ bin/openocd -s share/openocd/scripts -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp-wroom-32.cfg
Open On-Chip Debugger v0.10.0-esp32-20190313 (2019-03-13-09:52)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 500 kHz
Info : Configured 2 cores
esp32 interrupt mask on
Info : clock speed 500 kHz
Info : esp32: Debug controller 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 0 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Debug controller 1 was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core 1 was reset (pwrstat=0x5F, after clear 0x0F).
Info : Detected debug stubs @ 3ffb26f8 on core0 of target 'esp32'
Error: No symbols for FreeRTOS
Info : Target halted. PRO_CPU: PC=0x400E27F6 (active) APP_CPU: PC=0x400E27F6
Info : Target halted. PRO_CPU: PC=0x4009171A (active) APP_CPU: PC=0x400E27F6
Info : Flash mapping 0: 0x10020 -> 0x3f400020, 34 KB
Info : Flash mapping 1: 0x20018 -> 0x400d0018, 73 KB
Info : Auto-detected flash size 4096 KB
Info : Using flash size 4096 KB
Info : Using flash size 76 KB
Info : Using flash size 36 KB
Warn : negative reply, retrying
Info : dropped 'gdb' connection
When I run gdb I get:
user1@NUCi7Linux ~/esp/blink $ xtensa-esp32-elf-gdb -x gdbinit build/blink.elf
GNU gdb (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a) 7.10
Copyright (C) 2015 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "--host=x86_64-build_pc-linux-gnu --target=xtensa-esp32-elf".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from build/blink.elf...done.
Ignoring packet error, continuing...
warning: unrecognized item "timeout" in "qSupported" response
gdbinit:1: Error in sourced command file:
Bogus trace status reply from target: OK
(gdb)
Any help much appreciated, thanks.
debugging problem: unrecognized item "timeout" in "qSupported" response
Re: debugging problem: unrecognized item "timeout" in "qSupported" response
Can you try asking OpenOCD to reset and halt the target, and only then connect GDB? The command would be:
bin/openocd -s share/openocd/scripts -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp-wroom-32.cfg -c "init; reset halt"
Looks like the same problem. Is the devkitj interface the right one to use? I'm using the esp-prog with only the 4 jtag lines, ground, and Vjtag connected.
openocd window
user1@NUCi7Linux ~/esp/openocd-esp32 $ bin/openocd -s share/openocd/scripts -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp-wroom-32.cfg -c "init; reset halt"
none separate
Info : Target halted. PRO_CPU: PC=0x40000400 (active) APP_CPU: PC=0x40000400
Info : Target halted. PRO_CPU: PC=0x5000004B (active) APP_CPU: PC=0x00000000
Info : esp32: Core 0 was reset (pwrstat=0x1F, after clear 0x0F).
<pauses here while I run gdb in the other window>
Info : Target halted. PRO_CPU: PC=0x4009171A (active) APP_CPU: PC=0x40000400
gdb window:
(gdb)
openocd window
none separate
gdb window:
(gdb)
Okay, thanks for trying that. Could you please submit an issue at https://github.com/espressif/openocd-esp32/issues, mentioning the IDF version you are using to build the app, and attaching openocd log output. Please include -d3 flag on the command line of OpenOCD to get more verbose logs. Also if you can attach you build/blink.elf, build/blink.bin, build/bootloader.bin, that would be great. Thanks.
So I wiped out my esp-idf, toolchain, openocd, and example code and started over, and it works now. I thought I had the latest, but something must have been out of sync. Thanks for the help.
As a parting note I also had a problem with the error message:
Error: esp32: Failed to read insn (-4)!
Error: esp32: Failed to add SW BP!
Error: can't add breakpoint: resource not available
I was able to fix this by adding
-c "gdb_breakpoint_override hard"
to the openocd command line:
bin/openocd -c "gdb_breakpoint_override hard" -s share/openocd/scripts -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp-wroom-32.cfg
If you can reproduce the conditions where OpenOCD fails to set the software breakpoint in flash, please do file an issue on Github as suggested above. We would like to fix such issues.
Users browsing this forum: Baidu [Spider], Google [Bot], PetalBot and 2 guests
