ESP32S Node MCU can not blink
hoahoctro
Postby hoahoctro » Thu Jul 11, 2019 3:50 pm
I bought this board https://www.aliexpress.com/item/3280788 ... 4c4dGapEIG
(The yellow board, which has only one led onboard)
When uploading blink sketch, it doesnt work, but other sketch is ok
In this case, which pin is connected to the only led onboard ? :( :( :( :( :(
mikemoy
Re: ESP32S Node MCU can not blink
Postby mikemoy » Sun Jul 14, 2019 3:03 pm
You are going to have to get the schematic for the board to be sure. Many of these boards that only have one led is used for the power led.
ckovamees
Postby ckovamees » Thu Jul 18, 2019 5:54 pm
Try using the LED pin number 2 instead of the default sample value.
