problem with simple esp_mesh_send command
cgfoed
Postby cgfoed » Thu Jul 18, 2019 8:02 am
I'm using the current ESP-IDF on eclipse 4.12, trying to modify the internal_communication_example.
My goal in the end is to aggregate sensor data across the Mesh which shall be send to the Router which is also an ESP32 with softAP.
The basic setup seems to work for now. I've observed my small network electing a root, meshing together and connecting to the "router-ESP".
So far so good.
Now I'm trying to send data from a leaf or a node to the router-ESP.
I created a new task but I can't figure out why I'm getting this error:
incompatible types when assigning to type 'ip4_addr_t' {aka 'struct ip4_addr'} from type 'u32_t' {aka 'unsigned int'}	mesh_main.c	/internal_communication_example/main	line 398	C/C++ Problem
void sensor_test(void *arg)
	u32_t greetings = 123456;
    mesh_data_t data;
    data.data = &greetings; //todo
    data.size = sizeof(greetings); //todo
    data.proto = MESH_PROTO_BIN;
    data.tos = MESH_TOS_P2P;
    is_running = true;
    while (is_running) {
        /* non-root do nothing but print */
        if (!esp_mesh_is_root()) {
            vTaskDelay(10 * 1000 / portTICK_RATE_MS);
            continue;
         mip_t broker_addr;
         broker_addr.ip4 = ipaddr_addr("192.168.2.2");
		 broker_addr.port = 1883;
         esp_mesh_send(&broker_addr, &data, MESH_DATA_TODS, NULL, 0);
    vTaskDelete(NULL);
I do understand the nature of the error, but I don't understand why it occurs, since;
u32_t ipaddr_addr(const char *cp);
<<returns a u32_t
and "mip_t" comes down to a u32_t as well:
typedef union {
    uint8_t addr[6];    /**< mac address */
    mip_t mip;          /**< mip address */
} mesh_addr_t;
looking for "mip_t" shows:
typedef struct {
    ip4_addr_t ip4;    /**< IP address */
    uint16_t port;     /**< port */
} __attribute__((packed)) mip_t;
looking for "ip4_addr_t" shows:
typedef struct ip4_addr ip4_addr_t;
looking for "ip4_addr " reveals:
struct ip4_addr {
  u32_t addr;
What exactly is my problem here?
And btw; it would be highly appreciated to have more code examples for all the functions and workings of the mesh.
Thanks!
it_zzc
Re: problem with simple esp_mesh_send command
Postby it_zzc » Thu Jul 18, 2019 10:33 am
The reason for the error is due to the parameter type mismatch, and your usage is also wrong.
We recommend that you develop on ESP-MDF, and there are rich examples on ESP-MDF.
https://gitlab.espressif.cn:6688/application/esp-mdf
cgfoed
Postby cgfoed » Thu Jul 18, 2019 1:25 pm
Well, thanks for that advice...
Is there any additional help somebody can offer?
ESP_yudong
Postby ESP_yudong » Thu Jul 18, 2019 1:49 pm
Is this the line 398 in mesh_main.c ?
The type of broker_addr.ip4.addr is u32_t, but broker_addr.ip4 is not.
cgfoed
Postby cgfoed » Fri Jul 19, 2019 6:19 am
is there a code snippet for sending data to an mesh-external IP anywhere?
To answer your question:
Yes, this is line 398 - i'm aware that the error is located at that line.
cgfoed
Postby cgfoed » Fri Jul 19, 2019 12:50 pm
if somebody else comes across this problem; I'm using this workaround, written by ugallu now:
https://github.com/espressif/esp-idf/issues/2028
