I have problems running the IR-example with a real transceiver/receiver.
I'm getting sometimes this error:
rmt: RMT RX BUFFER FULL
I'm getting this in normal use after some time. The easiest way for me to reproduce this is to run the code in self test mode with a real transceiver/receiver. It seems that
if(item) {
becomes false before this happens. So if I get it right the buffer should be empty.
I will append my Log. I have add a debug output at line 312 "No return of item".
By the way, the margin is to small for real receivers. (20µS is only one carrier wave cycle) I have set it to 120µS.
Can anybody help me with this issue?
Regards
Peter
IR Nec example
IR Nec example
- espLog.txt.zip
- Log
- (1016 Bytes) Downloaded 481 times
Re: IR Nec example
I am also getting the same issue.
Re: IR Nec example
https://esp32.com/viewtopic.php?f=13&t= ... 818#p47818
If you are still on these issues, the above thread will definitely help you
Thank you.
Please check out this thread
Thank you.
Users browsing this forum: Baidu [Spider] and 134 guests
