Hi. I have been trying over the past days to get an ESP-Now Gateway to work with no luck.
Or Its ESPNow or WiFi. The moment I add both ESP-Now stops working.
Are there any examples of this working somewhere?
I have seen some for the ESP8266 but it reboots after every ESPNow message arrives. I have read that the ESP32 can handle both at the same time.
Thanks.
George.
ESP-Now
Re: ESP-Now
Hi George,
I am not even able to run the espnow example. It says ESP_ERROR_CHECK failed: esp_err_t 0x3002 (ESP_ERR_WIFI_NOT_STARTED) at...
I tried this on the master branch. Nor sure if it is a bug or a misconfiguration, although I set all the parameters in menuconfig.
