I can not get wificlient working
PeWosT
Postby PeWosT » Wed Feb 01, 2017 4:02 pm
I am trying to start the wificlient example, when I open the serial port it shows always "wifi: reconnect".
I am working with the esp32 development kit from espressif.
This is the example code I use:
 *  This sketch sends data via HTTP GET requests to data.sparkfun.com service.
 *  You need to get streamId and privateKey at data.sparkfun.com and paste them
 *  below. Or just customize this script to talk to other HTTP servers.
#include <WiFi.h>
const char* ssid     = "Xiaomi_8912";
const char* password = "M10s2I87kQpT";
const char* host = "data.sparkfun.com";
const char* streamId   = "....................";
const char* privateKey = "....................";
void setup()
    Serial.begin(115200);
    delay(10);
    // We start by connecting to a WiFi network
    Serial.println();
    Serial.println();
    Serial.print("Connecting to ");
    Serial.println(ssid);
    WiFi.begin(ssid, password);
        delay(500);
        Serial.print(".");
    Serial.println("");
    Serial.println("WiFi connected");
    Serial.println("IP address: ");
int value = 0;
void loop()
    delay(5000);
    ++value;
    Serial.print("connecting to ");
    Serial.println(host);
    // Use WiFiClient class to create TCP connections
    WiFiClient client;
    const int httpPort = 80;
    if (!client.connect(host, httpPort)) {
        Serial.println("connection failed");
        return;
    // We now create a URI for the request
    String url = "/input/";
    url += streamId;
    url += "?private_key=";
    url += privateKey;
    url += "&value=";
    url += value;
    Serial.print("Requesting URL: ");
    Serial.println(url);
    // This will send the request to the server
    client.print(String("GET ") + url + " HTTP/1.1\r\n" +
                 "Host: " + host + "\r\n" +
                 "Connection: close\r\n\r\n");
    unsigned long timeout = millis();
    while (client.available() == 0) {
        if (millis() - timeout > 5000) {
            Serial.println(">>> Client Timeout !");
            client.stop();
            return;
    // Read all the lines of the reply from server and print them to Serial
    while(client.available()) {
        String line = client.readStringUntil('\r');
        Serial.print(line);
    Serial.println();
    Serial.println("closing connection");
and this is that I see in the serial port:
  • ets Jun 8 2016 00:22:57
    rst:0x1 (POWERON_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
    rst:0x10 (RTCWDT_RTC_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
    configsip: 0, SPIWP:0x00
    mode:DIO, clock div:1
    load:0x3ffc0008,len:4
    load:0x3ffc000c,len:1708
    load:0x40078000,len:3124
    load:0x40080000,len:256
    entry 0x40080034
    tcpip_task_hdlxxx : 3ffd5b70, prio:18,stack:2048
    I (1445) wifi: frc2_timer_task_hdl:3ffd7ff8, prio:22, stack:2048
    I (1456) wifi: pp_task_hdl : 3ffda7fc, prio:23, stack:8192
    Connecting to Xiaomi_8912
    I (1472) wifi: mode : softAP (24:0a:c4:00:3a:17)
    I (1473) wifi: mode : sta (24:0a:c4:00:3a:16) + softAP (24:0a:c4:00:3a:17)
    dhcp server start:(ip: 192.168.4.1, mask: 255.255.255.0, gw: 192.168.4.1)
    ....I (3679) wifi: reconnect
    ....I (5883) wifi: reconnect
    .....I (8087) wifi: reconnect
    ....I (10291) wifi: reconnect
    .....I (12494) wifi: reconnect
Angus
Re: I can not get wificlient working
Postby Angus » Tue Feb 07, 2017 11:44 pm
There's something unusual going on, because the example mentions both STA (client) and AP (access point) mode, but the code seems to be designed to just be a client. Are you sure the sketch is uploading to the ESP32 properly?
PeWosT
Postby PeWosT » Wed Feb 08, 2017 4:32 am
First of all thank you foro your response.
I upload the program with GPIO throwing down, wheb the program has been uploaded I reboot the esp32
shadow
Postby shadow » Wed Feb 08, 2017 4:19 pm
That's how the Arduino WiFi client behaves, somehow the softAP is started :(
PeWosT
Postby PeWosT » Wed Feb 08, 2017 4:43 pm
Have any solution with the arduino ide?
Users browsing this forum: Google [Bot], PerplexityBot and 1 guest
