Hi All,
I am new to this environment ,but went through all the guides and reference about jtag dbugging wrover kit documents still i am stuck in middle,unable to debug any c CODE on eclipse with wrover kit.
trying from many days but not able to make it up can you guys help me in this issue..?
regards
Atul
Can anyone guide me for debugging code on eclipse using WROVER kit
Re: Can anyone guide me for debugging code on eclipse using WROVER kit
Just to rule out the obvious. Are you able to debug without using eclipse (i.e. running OpenOCD and GDB)?
Hi Dazz,Just to rule out the obvious. Are you able to debug without using eclipse (i.e. running OpenOCD and GDB)?
I am not geting that only its working or no.
openocd is detecting the remote target i think when i try to launch the debug it gives some error i am attaching the
screenshot of both openocd and gdb command line responces.
anything else you need let me know.
Regards
Atul
- staus_debug.png (90.46 KiB) Viewed 3738 times
Users browsing this forum: Baidu [Spider], Bytespider, Qwantbot and 2 guests
