mwifi_write keep getting MDF_ERR_MWIFI_TIMEOUT
teckhaokoh
Postby teckhaokoh » Fri Aug 16, 2019 6:01 am
W (2665878) [mwifi, 778]: <MDF_ERR_TIMEOUT> Node failed to send packets, data_flag: 0x32, dest_mac: 30:ae:a4:5a:6d:bd
Keep getting the timeout message as above when sending data to parent node.
It's able to send at the beginning, then get into this timeout after some time, and will never get back to normal even if I resend every 5 seconds.
Any idea?
Bond
Re: mwifi_write keep getting MDF_ERR_MWIFI_TIMEOUT
Postby Bond » Thu Aug 22, 2019 6:27 am
1. Is your parent node receiving mwifi_read or mwifi_root_read?
2. You can parameter `mwifi_example` to see what is the difference.
3. Can you provide your code? How can I reproduce it?
