Mesh uses HT40, this uses too many channels, causing issues with existing Wifi infrastructure in large buildings.
Is it possible to force everything to go down to HT20, so less 2.4GHz channels are used?
Mesh uses HT40, this uses too many channels. Can I used HT20?
Re: Mesh uses HT40, this uses too many channels. Can I used HT20?
Hi hassan789,
Please check this link if it helps: https://docs.espressif.com/projects/esp ... fi-ht20-40
tried both modes, and it did not work.... was this ever tested?
esp_wifi_set_mode(WIFI_MODE_APSTA);
esp_wifi_set_bandwidth(ESP_IF_WIFI_AP, WIFI_BW_HT20);
esp_wifi_set_mode(WIFI_MODE_STA);
got it to work, doing the following:
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_APSTA));
ESP_ERROR_CHECK(esp_wifi_set_bandwidth(ESP_IF_WIFI_STA, WIFI_BW_HT20));
ESP_ERROR_CHECK(esp_wifi_set_bandwidth(ESP_IF_WIFI_AP, WIFI_BW_HT20));
Users browsing this forum: No registered users and 42 guests
