PSRAM cache - how/when to update toolchain?
https://github.com/espressif/esp-idf/issues/2892
Thought I might be better asking here my question about when/how to update the toolchain on Windows as it might be too basic for the GitHub issue.
Any advice appreciated, was waiting for ESP IDF 3.3 to release our product, but I am confused what to do about this PSRAM issue. I don't want a time bomb in the field.
Re: PSRAM cache - how/when to update toolchain?
Any advice appreciated. Want to start beta testing our new product.
We should start integrating this into mainline next week (it's a holiday in China now).
Thanks, I'd really like to install the updated toolchain on windows, but I cannot work out how to do it. I can manage to add the volatiles and change the binaries in newlib.
I can extract xtensa-esp32-elf-win32-1.22.0-98-g4638c4f-5.2.0-20190827.tar but the contents are smaller than the original toolchain and there is a problem with symbolic links (see next post for permissions).
It looks like it belong in C:\msys32\opt
Looking at https://docs.espressif.com/projects/esp ... nvironment
I used 7zip in administrator mode (so it was able to create symbolic links) to unpack the tar in a new directory.
# Automatically download precompiled toolchain, unpack at /opt/xtensa-esp32-elf/
TOOLCHAIN_ZIP=xtensa-esp32-elf-win32-1.22.0-80-g6c4433a-5.2.0.zip
echo "Downloading precompiled toolchain ${TOOLCHAIN_ZIP}..."
cd ~
curl -LO --retry 10 http://dl.espressif.com/dl/${TOOLCHAIN_ZIP}
cd /opt
rm -rf /opt/xtensa-esp32-elf # for upgrades
unzip ~/${TOOLCHAIN_ZIP}
rm ~/${TOOLCHAIN_ZIP}
cat > /etc/profile.d/esp32_toolchain.sh << EOF
# This file was created by ESP-IDF windows_install_prerequisites.sh
# and will be overwritten if that script is run again.
export PATH="/opt/xtensa-esp32-elf/bin:\$PATH"
EOF
# clean up pacman package cache to save some disk space
pacman --noconfirm -Scc
cat << EOF
MSYS2 environment is now ready to use ESP-IDF.
1) Run 'source /etc/profile' to add the toolchain to
your path in this terminal. This command produces no output.
You only need to do this once, future terminals do this
automatically when opened.Is there some unzip I can do with the new toolchain that merges it with the old one to get it up to size or am I completely missing the point?
Toolchain path: /opt/xtensa-esp32-elf-new/bin/xtensa-esp32-elf-gcc
WARNING: Toolchain version is not supported: crosstool-ng-1.22.0-98-g4638c4f6
Expected to see version: crosstool-ng-1.22.0-80-g6c4433a
Please check ESP-IDF setup instructions and update the toolchain, or proceed at your own risk.
Compiler version: 5.2.0
Python requirements from C:/msys32/home/jcsba/esp/esp-idf/requirements.txt are satisfied.
export PATH="$PATH:/opt/xtensa-esp32-elf-new/bin"Comments on anything I'm doing wrong here please.
Even if I rename the original toolchain, builds still work, but the new toolchain is 300MB smaller!!?? I guess I just don't understand these symbolic links and where they point to.
Update: despite the smaller size, the toolchain and applications built with it do work.
Users browsing this forum: ChatGPT-User, Google [Bot], meta-externalagent and 3 guests
