Calling a C++ class-method
dasarne
Postby dasarne » Sat Nov 02, 2019 7:52 pm
Hello, everybody,
I want to call a method in a C++ class from an event in ESP-IDF in an xTask.
Here is the class and method „dispatch“ I want to call:
Code: Display.h Select all
* Display.h
* Created on: 01.11.2019
* Author: arne
#ifndef COMPONENTS_HARDWARE_DISPLAY_H_
#define COMPONENTS_HARDWARE_DISPLAY_H_
#include "Modell.h"
class Display {
public:
Display();
virtual ~Display();
/**Analysiert die Befehle des Frontends und ruft entsprechende Methoden auf*/
void dispatch(char *str);
private:
Modell theModell;
#endif
Code: Display.cpp Select all
* Display.cpp
* Author: arne
#include <Display.h>
Display::Display() {
// TODO Auto-generated constructor stub
Display::~Display() {
// TODO Auto-generated destructor stub
void Display::dispatch(char *str) {
To encapsulate the method in an external "C" method I wrote the following wrapper:
Code: DisplayC-Wrapper.h Select all
* DisplayC-Wrapper.h
* Author: arne
#ifndef COMPONENTS_HARDWARE_DISPLAYC_WRAPPER_H_
#define COMPONENTS_HARDWARE_DISPLAYC_WRAPPER_H_
#ifdef __cpluscplus
class Display;
extern "C" {
#else
struct Display;
typedef struct Display Display;
#endif
Display *Display_new();
void Display_dispatch(Display *instance, char *str);
#ifdef __cpluscplus
#endif
#endif
Here is the implementation of the wrapper:
Code: DisplayC-Wrapper.c Select all
* DisplayC-Wrapper.c
* Author: arne
#include "DisplayC-Wrapper.h"
#include "Display.h"
return new Display();
instance->dispatch(str);
And here the corresponding call in the xTask:
Code: display.c Select all
void rx_task() {
Display *instance = Display_new();
Display_dispatch(instance,"Test");
Everything compiles but doesn't link.
I got the following error-message at linkage time:
What do I have to do to make this linking?
Are there suitable compiler flags?
Is it possible to address C++ classes from C methods at all?
Is there more information about this topic somewhere? The best would be to find a working example...
Many greetings
Arne
All theory, my friend, is grey, But green is life's glad golden tree.
PeterR
Re: Calling a C++ class-method
Postby PeterR » Sun Nov 03, 2019 11:26 am
Passing the class instance around as 'void *' and then casting is the usual trick.
If the class member dispatch is static then you can just pass the member address as a function pointer.
extern "C" CToCPlusPlus(void *displayPtr, const chat *str) {
   ((Display *)displayPtr)->dispatch(str);
Users browsing this forum: Baidu [Spider], PerplexityBot, YisouSpider and 4 guests
