Clion - Error Windows requires a prebuilt mconf-idf
batFastard
Postby batFastard » Mon Nov 04, 2019 8:12 pm
Can anyone help me understand what CLion is needing? I am new to the esp32 and espressif in general.
Trying to get it running in on a ESP32 WROOM-32D in CLion.
I went thru the setup process, and I can get it to build from the command line. But when I setup a new esp32 project in CLion I get this error, and I can't find anyone else reporting this error.
ESP_Angus
Re: Clion - Error Windows requires a prebuilt mconf-idf
Postby ESP_Angus » Tue Nov 05, 2019 3:00 am
Hi bF,
Did you run the Windows setup installer? This should install a prebuilt mconf-idf.exe binary, but you may need to configure the CLion project's PATH variable so that it can be found on the path.
(If using IDF on the command line, the export.bat script step takes care of this.)
batFastard
Postby batFastard » Tue Nov 05, 2019 8:44 pm
I thought I went thru all of the installation instructions. Do you have a link for the windows installer, or to the directions for using it?
I see a mconf-idf.exe.
So I need to add the path to the mconf-idf.exe to my projects include path?
Thanks for the help
bf
Users browsing this forum: Baidu [Spider] and 24 guests
