I'm excited to see the new support for an SPI-connected Ethernet solution (DM9051) described in the 4.0-beta1 release notes: https://github.com/espressif/esp-idf/re ... v4.0-beta1
I assume it will cut down the required IO pins from 9 (RMII) to 4 (SPI). I'm currently using the LAN8720 but I'm out of IO pins which I desperately need for other features.
Does anyone have an example schematic and evaluation board yet which incorporates the DM9051?
DM9051 SPI Ethernet example?
Re: DM9051 SPI Ethernet example?
Anyone?
I've also come across the Microchip ENC28J60 solution which is being used in the Arduino community. It is only 10Mb vs. DM9051 10/100Mb. Will the speed decrease (from my current LAN8720) be noticeable with my simple web-server based on libesphttpd?
ENC28J60:
http://www.microchip.com/wwwproducts/De ... e=en022889
The schematic of the ENC28J60-based EtherCard shield is here:
https://www.open-electronics.org/low-co ... -enc28j60/
This repo shows the ENC28J60 connections between the Ethercard and ESP32:
https://github.com/8-DK/EtherCard
I see there is an availability problem for the DM9051, there are no US distributors carrying it. Just one Chinese distributor showing up on Octopart:
https://octopart.com/search?q=DM9051
ENC28J60:
JimmyPedersen
Also have a look at
https://www.microchip.com/wwwproducts/en/ENC424J600
I second this request. Any engineers at espressif know where dm9051 dev boards can be purchased? I did find this schematic: https://www.dacomwest.de/images/Dateien ... o_v2.1.pdf
I found this note that discourages use of enc28j60 - https://github.com/espressif/esp-idf/bl ... md?plain=1
It looks like (for now) the W5500 has the best cost and availability in the US. ~$2 https://octopart.com/w5500-wiznet-30858120?r=sp
Users browsing this forum: Bing [Bot], Bytespider, Qwantbot and 2 guests
