My ESP32 module was connected to a WLAN-repeater (Fritz-Repeater).
Now I moved it back near to the router (Fritzbox) but it still connects to the far away repeater, even that the router signal is much stronger. The result: slow & difficult traffic.
Why doesn't ESP32 select the stronger signal?
An Android does not show that behavior.
Can I do anything about it?
I'm using: ESP-IDF v4.0-dev-1136-g28f1cdf5e-dirty
ESP32 still connects to repeater even when its signal is very weak
JoeThibodeau
Re: ESP32 still connects to repeater even when its signal is very weak
You can use RSSI to determine which connection is strongest and control connectivity in your code.
Users browsing this forum: Bytespider, Semrush [Bot] and 1 guest
