esp-idf with eclipse script runing
Zakaria13
Postby Zakaria13 » Fri Nov 29, 2019 11:53 pm
hello
i am testing an example for ESP32 that let me connect to AWS server.
for that i am using ESP-IDF and Eclipse.
there is a file named component.mk that contains a script for generating a ky header file ( needed to connect to AWS server ).
this is the content of this file:
COMPONENT_EXTRA_CLEAN := certs.h
main.o: certs.h
certs.h: $(COMPONENT_PATH)/certs/root-CA.crt $(COMPONENT_PATH)/certs/certificate.pem.crt $(COMPONENT_PATH)/certs/private.pem.key
$(Q) rm -f certs.h
$(Q) echo "const char *rootCA =" >> certs.h
$(Q) cat $(COMPONENT_PATH)/certs/root-CA.crt | tr -d "\r" | awk '{ print "\""$$0"\\r\\n\""}' >> certs.h
$(Q) echo ";" >> certs.h
$(Q) echo "const char *devicePrivateKey =" >> certs.h
$(Q) cat $(COMPONENT_PATH)/certs/private.pem.key | tr -d "\r" | awk '{ print "\""$$0"\\r\\n\""}' >> certs.h
$(Q) echo "const char *deviceCert =" >> certs.h
$(Q) cat $(COMPONENT_PATH)/certs/certificate.pem.crt | tr -d "\r" | awk '{ print "\""$$0"\\r\\n\""}' >> certs.h
i am unable to run this script, is therea mean to do that in eclipse?
thanks.
Zakaria
Users browsing this forum: Google [Bot] and 20 guests
