WARNING: Toolchain version is not supported: esp32-2019r1 Expected to see version: esp-2019r2
ralphs99
Postby ralphs99 » Thu Dec 05, 2019 2:53 am
Hello all,
I've just downloaded 'esp32_win32_msys2_environment_and_toolchain-20190611', installed msys32 and set the path in 'export_idf_path.sh' per the instructions at 'Standard Setup of Toolchain for Windows (Legacy GNU Make)'
I'm seeing this warning when compiling: "WARNING: Toolchain version is not supported: esp32-2019r1 Expected to see version: esp-2019r2".
Is there a newer toolchain than the one linked to? Do I need to be concerned about the warning?
Thanks in advance!
Angus
Re: WARNING: Toolchain version is not supported: esp32-2019r1 Expected to see version: esp-2019r2
Postby Angus » Thu Dec 12, 2019 12:18 am
Hi ralphs,
Sorry, the new MSYS2 zip update is lagging the toolchain update. It will be updated before the final v4.0 release.
In the meantime, you can download the new toolchain from https://dl.espressif.com/dl/xtensa-esp3 ... -win32.zip and then delete the old toolchain (under C:\msys32\opt) and replace it with this one.
Angus
borch84
Postby borch84 » Fri Dec 27, 2019 11:51 pm
I am having the same issue.
I recently updated esp-idf master repo with git pull
$ git describe --tags --dirty
v4.1-dev-1572-g30372f5a4-dirty
/esp-idf$ ls
add_path.sh     CONTRIBUTING.rst  export.bat  install.bat  Kconfig  README_CN.md      sdkconfig.rename      tools
CMakeLists.txt  docs              export.ps1  install.ps1  LICENSE  README.md         SUPPORT_POLICY_CN.md
components      examples          export.sh   install.sh   make     requirements.txt  SUPPORT_POLICY.md
WARNING: Toolchain version is not supported: crosstool-ng-1.22.0-80-g6c4433a
Where do I get the linux version esp-2019r2 of the toolchain?
Thanks.
Angus
Postby Angus » Mon Dec 30, 2019 5:40 am
For IDF v4.0 and later, we recommend using the new "ESP-IDF Tools" management system which is part of the master branch IDF version:
https://docs.espressif.com/projects/esp ... -the-tools
Users browsing this forum: Baidu [Spider], ChatGPT-User, DuckDuckGo [Bot], Google [Bot] and 1 guest
