Updating lyrat 4 3 firmware
benbiles
Postby benbiles » Sun Dec 22, 2019 1:04 pm
Hi, i am trying to update all the lyrat 4.3 firmwares. In the lyrat 4.3 manual it shows 4 bin images selected to be flashed.
I have succseffuly flashed the bootloader v2 for esp32 at 0x1000 but there are 3 others on differnt partitions in the flash?
Are there any specific to lyrat 4.3?
I am trying to eliminate the possibilty I have a defective board as the audio in pass through example is coming through to headphones in mono regardless of if I use the 2 mics or line input set to 0db on aux input channel 2 on the ADC.
Also are there any other known issues with mono audio only on this dev board?
benbiles
Re: Updating lyrat 4 3 firmware
Postby benbiles » Sun Dec 22, 2019 6:58 pm
OK scrap that question.
I'm using EPS-IDF and ESP-ADF so not relevant.
Also hardware is not broken !
